Door Rough Opening Dimensions
Old 01-31-2012, 09:36 PM   #1
txgencon's Avatar
Rewards Points: 384
Since the 70's, I've framed (or had framed) door rough openings 2-1/2" over. But jamb stock seems to have evolved from a full 3/4" to 5/8" thick or even less nowadays. Thinking of going to only 2" over. What are your practices?
txgencon is offline
Old 01-31-2012, 09:41 PM   #2
MikeyJP1980's Avatar
Rewards Points: 75
Re: Door Rough Opening Dimensions
2” is all we have ever used! Works great for us!
MikeyJP1980 is offline
Old 01-31-2012, 09:41 PM   #3
Elyrain's Avatar
Rewards Points: 416
I always get the product info on the door used Before rough and use that, plus shimming.
Ca A&B
Elyrain is offline
Old 01-31-2012, 09:42 PM   #4
Hmbldr's Avatar
Trade: Residential contractor
Rewards Points: 150
Likewise, learned at 2 1/2" and like it that way. This gives plenty of leeway to make the fit perfect plumb and shift to desired centering. Of course, we use mostly wider casings, 3 1/2" or larger, so the gap is always well covered.
Hmbldr is offline
Old 01-31-2012, 09:45 PM   #5
txgencon's Avatar
Rewards Points: 384
Are you saying a 2'-8" door isn't always exactly 32" wide in your area? That thought never occurred to me. I can understand with windows - they're either actual or 1/2" under callout depending on the manufacturer.
txgencon is offline
Old 01-31-2012, 09:46 PM   #6
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 338
Our interior doors get framed door size plus 2 1/4. Our suppliers doors are a full 36 or 32 plus reveal and they still use 3/4 jambs so 2 inch over gets a little tight at time. For exterior doors typically they are 2 1/4 over also per the ro specs from manufacturer.
overanalyze is online now
Old 01-31-2012, 09:48 PM   #7
dkillianjr's Avatar
Rewards Points: 2,464
I have always framed 2" over. It seems to work out pretty good.
dkillianjr is offline
Old 01-31-2012, 09:51 PM   #8
txgencon's Avatar
Rewards Points: 384
I guess I should have prefaced my question with a recent experience with some volunteer work for H4H. I was assigned to hang six doors in the three bedrooms. The casing was the tiniest stuff I've ever seen - 1-13/16" wide.
txgencon is offline
Old 01-31-2012, 10:02 PM   #9
manipulator of wood
I Mester's Avatar
Trade: general contractor
we've always framed the rough opening 2" over the nominal dimension. never failed us.
I just love the smell of sawdust in the morning!
I Mester is offline
Old 01-31-2012, 10:03 PM   #10
slowsol's Avatar
Rewards Points: 2,192
Have always framed 2" over.
-John
slowsol is offline
Old 01-31-2012, 10:09 PM   #11
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 652
I frame 2" over most of the time, but if I'm not rushed and the planets are in proper alignment, I do 1 3/4 just because I can.
Tinstaafl is offline
Old 02-01-2012, 05:53 AM   #12
Kent Whitten's Avatar
Rewards Points: 2,040
In GENERAL.....2". Exterior doors I go 1/2" wider, double doors 2-1/2, bypass actual to + 1 depending on the casing. 2-1/2 on the height every time. Lots of other variables like handicap accessible.
SalmonFallsCabinetry.com
Kent Whitten is offline
Old 02-01-2012, 07:06 AM   #13
TimNJ's Avatar
Rewards Points: 2,008
I like 2 1/2. 2" is too tight, it only leaves about a 1/4 and that's too small to get the spray foam nozzle into.
TimNJ is offline
Old 02-01-2012, 07:54 AM   #14
Elyrain's Avatar
Rewards Points: 416
I don't work on houses, commercial only. So yes I have made the mistake of the RO being to big or to small by using some generic addition. Never again. It doesn't take all that much time to find out the product info before hand.
I actually don't even remember the last time I installed a 2-8 door, maybe on a closet somewhere but everything is 3-0+ out here because of ADA.
Elyrain is offline
Old 02-01-2012, 09:21 AM   #15
Commercial Contractor
Mud Master's Avatar
Trade: Commercial General Contractor
Rewards Points: 1,000
Send a message via AIM to Mud Master
2 over 1 up, never fails. 3'0x6'8 and up go in like butter
Originally Posted by katoman View Post
And when the day is done, I can look myself in the mirror, with pride, and say " you're a craftsman, well done. "
Mud Master is offline
Old 02-01-2012, 10:14 AM   #16
jb4211's Avatar
Rewards Points: 2,306
I've always used 2" and never had an issue.
Jon
jb4211 is offline
Old 02-01-2012, 10:15 AM   #17
jb4211's Avatar
Jon
jb4211 is offline
Old 02-01-2012, 05:18 PM   #18
pro
413Sean's Avatar
Trade: residential/framer
Rewards Points: 326
I go with 2 1/2"(width and height) on exterior doors and 2" on interior doors, usually allows ample shiming room
413Sean is offline
Old 02-01-2012, 08:44 PM   #19
knucklehead's Avatar
Trade: Extraordinary Carpenter
Rewards Points: 2,702
It depends on how plumb your walls are.
If they are real good 2" is enough.
I used to do 2 1/4, but since I started doing trim behind my framing ,I have cut it down to 2"
NKLHD
knucklehead is offline
opening a wall in a commercial site AustinDB Construction 22 01-05-2012 01:28 PM
cutting an opening 9'by 9' in a block wall WRer Construction 64 10-24-2011 11:02 AM
garage door opening question Pennyroyal's Masonry 10 05-21-2009 04:56 PM
Does fireplace opening in block wall opening need support? Square-One Masonry 6 11-22-2008 02:31 AM
Does fireplace opening in block wall opening need support? Square-One Construction 1 02-28-2006 01:59 AM
