Demolition Help
Old 12-24-2005, 07:30 AM   #1
SHRepairs's Avatar
Trade: Home Repair Services
Send a message via Yahoo to SHRepairs
Question
Demolition Help
I would like to know if their is a SQFT price, or hourly price in demolition of plaster from ceilings & walls.. Please help
SHRepairs is offline
Old 12-26-2005, 05:57 PM   #2
jmic's Avatar
Re: Demolition Help
I'de say what ever and where ever the market will bear.
Joe
jmic is offline
Old 12-26-2005, 09:35 PM   #3
Teetorbilt's Avatar
Re: Demolition Help
If you have to bid on demos, go high. I usually go T&M with a high est. You never know what you are getting into on these jobs.
My son hit a 1/4" soft copper gas line a few weeks ago. It was definitely a DIY job and ran from the kitch through the attic and to a bath. The HO had been there for 25 yrs. and didn't even know that gas was available in her area, there also were no indications (valve, reg., meter, appliances) that gas was present anywhere. I bent the line and crimped it with visegrips, the HO panicked, called the F.D. and I lost about 20 m/hrs. Bid high and have lots of pertaining clauses in your contract. Mine just got a little longer.
Albert Einstein
Teetorbilt is offline
Old 12-26-2005, 10:09 PM   #4
mdshunk's Avatar
Re: Demolition Help
Have this plaster tested first. The 20 bucks for the test at the local lab is worth it to know. I say this because some plaster men during certain years used asbestos as a filler/binder in the plaster. It can turn a simple plaster demo into a medium sized remediation job.
I've been on one government job that even had the asbestos guys there demoing sheetrock. The sheetrock didn't contain asbestos, but apparently the type of joint tape that was used in that building contained asbestos. Go figure.
I know that people requesting a demo bid didn't hire you as their hazard consultant, and some can get pretty worked up if you want to test for stuff like lead, asbestos, etc before you bid. If you find those things, then they officially "know", and have to take the necessary steps to keep that stuff from getting out or remediate it. Testing first is simple CYA on your part, I believe
mdshunk is offline
Central NJ Residential Construction Demolition Co. NatImpressions Help Wanted or Looking For Work 1 10-17-2008 11:43 PM
Demolition Sub-Topic? Nathan Excavation & Site Work 8 08-14-2007 01:00 AM
Cool Demolition Projects Wolf Excavation & Site Work 1 05-06-2006 07:07 PM
demolition of existing space cost estimate John H Construction 9 12-01-2005 11:37 PM
