Trade: remodeler
Deck Problem
I have a customer who asked me to fix a deck that the old builder did a bad job on and wont fix it; but will pay to have it fixed.
The deck is 45' long and 12' wide. The problem is he only used 2 x 6 to span the 12'. The deck is about 10 ' off the ground. Posts are 10' apart, outer band 2 x 8, and joists 16" on center. The deck is extremely bouncy, quite scary. There is no code enforcement as it is in a rural area. My question is how can i beef the deck up without tearing it down and spending a lot on materials. I thought about doubling up every other joist and adding some 45 degree bracing on the outside with 4 x 4 between the outside band and posts. Any ideas greatly appreciated. |
Re: Deck Problem
Run a girder under the 2x6's mid span with posts properly spaced.
Priced In
Trade: Exiled For Life
Re: Deck Problem
I would go 8" oc that is one hell of a span for 2x6 at even 12" oc. Please elaborate more on the 45 thing I am not picturing it.
Trade: carpenter/remodeler
Re: Deck Problem
i would do like joe. it is by far the easiest of the options. dig you post holes, set your posts and run a beam at midspan. it will take all the bounce out of the deck.
Custom Builder
Re: Deck Problem
Ditto!
Bob
Bob |
Trade: Custom deck builder
Re: Deck Problem
+1 more for what jim has to say... maybe even 2 beams... 2x6?? come on who uses that for joists? I never use less than 2x8 even for a 4' span after 8' I bump it up to 2x10 at over 14' I go to a 2x12. I would use at least a double 2x10 beam because a beam in the center carries twice the weight of something on the end. Click here for a multi beam span table from my local building department it is based upon 40 lbs LL and 15 lbs DL.
Trade: remodeler
Re: Deck Problem
Thanks, the problem with the girder across the middle is that the space under the deck will probably be used,as ther are french doors leading out from the basement and i want to try and conserve the view. Adding more posts would be a good idea though.
carpenter and builder
Trade: carpenter and builder
Re: Deck Problem
Definately run a beam mid span, you immediately halve the span of the joists and dont have to intefere with the existing structure.
#9 | |
Re: Deck ProblemQuote:
#10 | |
Plan B: If running girter is out of the question then I would reccomend sistering all 2x6 joist with 2x10"s
#11 | |
Charitable animal
Trade: decks
homo depot on 24" oc. I've seen it, its part of their "patented" parquet deck "system"
Trade: remodeler
Re: Deck Problem
thanks everyone.
Thinking about it a mid span beam would make it alot stronger and cheap than materials to double up every or every other joist. And also reduce the weight on the outside beam and posts. I think this is the only way; just have to sacrifice some space underneath. |
Priced In
Re: Deck Problem
Using the joist span table it the beam was set at 9' 5" inside measure the 2x6 joists would work for bare min considering they are hem fir #2. Then joists could then cantilever.
Bob
Trade: Truck driver / Equipment operator
Re: Deck Problem
If below deck clearance is a problem, maybe use 2x6 or 4x4 steel tubing about 1/4" wall. This will allow a longer span between posts as well. Just a thought.
#15 | |
Trade: Home Improvement
Bob Last edited by bob the builder; 02-18-2006 at 03:10 PM. |
#16 | |
Priced In
Re: Deck Problem
First off I would print off some span tables and give them to the original contractor and tell him to learn how to read them... Keep in mind the tables are based upon MINIMUM requirements overbuilding is the best way to go. If you really wanted to you could get a steel beam with some steel teleposts and I bet you could span the entire distance with 1 post on each end. But this require an engineer.
#18 |
Re: Deck Problem
Why do home owners/contractors build a deck using minimum construction standards and a few years later want to put a 2,000 gallon
Hot Tub on it and complain when they have to beef up the supports |
#19 |
Trade: remodeler
Re: Deck Problem
Appreciate all the ideas.
The customers are actually friends of mine. They have gone through 2 builders than never finished the job to build their new house. Both took the money and ran. The first crook (actually recommended by their bank) would never turn up to finish, half way through the project. So they hired a second guy that only used subcontractors , which never got payed and did bad work. Now the home owners are broke and cant afford a lawyer to get money back to finish the house. I feel bad for them being ripped off ,so i want to help them out. But i am so tired of all these so called contractors, that just make a bad name for all us honest guys in the trade.
| Used the new Correct Deck CX-personal review | IHI | Decks & Fencing | 22 | 07-27-2008 09:52 PM |
| Dry lower deck stuff | frostyfrost | Decks & Fencing | 12 | 05-19-2007 07:59 AM |
| Cedar Deck Prep Problems | Larman | Painting & Finish Work | 2 | 05-04-2007 05:31 PM |
| Riverside deck | Nick H | Decks & Fencing | 16 | 04-23-2007 06:59 PM |
| new cedar deck problem | mickchipp | Decks & Fencing | 5 | 12-04-2006 11:23 AM |
