Deck Over A Flat Roof
Old 04-18-2007, 03:59 PM   #1
Same Old's Avatar
Trade: Residential General
Does anyone have a good method for this? I've done it before but I never really liked the finish.
I'm hoping there is some deck system out there that is made for this.
The application I am looking at is for some type of wood deck with railing above 19x 20 garage.
Same Old is offline
Old 04-18-2007, 06:16 PM   #2
tcleve4911's Avatar
Trade: Remodeling contractor
Re: Deck Over A Flat Roof
Questions -
Can deck material touch the roof?
Is the flat roof rubber?
How much thickness is available to door accessing deck?
Back in Maine
Dubbin' Around
Doin' good stuff ......
tcleve4911 is offline
Old 04-18-2007, 06:32 PM   #3
Thom
thom's Avatar
I do it a lot.
Use a torchdown roof. built up with gravel will be a problem. Built up without gravel might be all right. Roof drainage needs to slope properly.
Install 2 X 4 Sleepers on pads, directly over joists or perpendicular to existing joists. They cannot go parallal but not directly over. The pads are concrete expansion joints. I'm sure you've seen the stuff, 3-1/2" wide by 8' long asphalt impregnated fiberboard.
Screw the deck to the sleepers.
You must make sure you have adequate drainage between the sleepers. Screw this up and you've got a problem
You must make sure the roof joists are sized for a floor load. Standard roof joists have an inadequate load capacity.
The problem with a built-up roof with gravel is that you will be pushing the gravel through the roofing over time, creating a leak.
The point of the pads under the sleepers is to even out the load on the roofing so you don'nt develop places where the sleepers cut through the roof over time.
thom is offline
Old 04-18-2007, 07:25 PM   #4
AtlanticWBConst's Avatar
Check this out:
http://www.bisondecksupports.com/
Looks like a great product. Discovered them at the Last JLC show. Only $12.00 a piece for the regular supports and $14.00 for the Heavy Duty.
- Build Well -
AtlanticWBConst is offline
Old 04-18-2007, 07:51 PM   #5
Same Old's Avatar
I've done the sleeper method over epdm, but I never really liked how it forces you to a single slope and the awkward drip edge.
Those Bison supports look like a good bet over a preformed foam underlay.
Thanks for the input.
Same Old is offline
Old 04-18-2007, 08:15 PM   #6
Same Old's Avatar
Originally Posted by tcleve4911 View Post
Questions -
Right now there is nothing built and the arch's plans are extremely lacking in details.
Same Old is offline
Old 04-19-2007, 07:37 PM   #7
RLGC's Avatar
Trade: General contracting
Have you concidered a fiber glass deck. The problem with rolled roof is its only guarenteed for ten years. ??. Wherever you nail or screw through is vulnerable to leaks. If you value what lies below your roof and don't want the inevitble headaches long term, fiber glass might be a good solution. I have used it twice for your situation. No complaints
RLGC is offline
Old 04-20-2007, 08:02 AM   #8
keepitstraight's Avatar
Trade: drywall, painting, trim, finish and custom carpentry
wife and i are looking at building ourselves a santa fe and i think that we've pretty much decided to go with an epdm membrane on the deck and covering the membrane with foam. apparently the main reason for failure on membranes is that even with uv resistance, they expand and contract in direct contact with sun and weather. then they shrink and ull loose. the foam prevents extremes on the membrane's expansion/contraction and gives you a safe place to lay duckboards, decking, etc.
i am definitely going to have to look at this attachment further though. thanks, atlwbconst. love this about these forums; see perspectives through a larger field of experience and widen the rut of habit.
thanks all.
keepitstraight is offline
Old 04-20-2007, 09:01 AM   #9
Same Old's Avatar
I'm not familiar with fiberglass decks. This is for a fairly nice neighborhood, I think I'll go with the Bison system over epdm with Ipe panels.
Same Old is offline
Old 04-04-2011, 01:39 AM   #10
M&R Roofing's Avatar
Trade: Roofing Contractor
When installed properly as a floating deck, a deck can sit on the roofing membrane. We are primarily installing two ply modified bitumen flat roofing systems. When we do install wood decks over the flat roofs, we ensure they are floating, so that there is no punture or penetration of the rubber membrane. The flat roof should be sloped appropriately as always and the decking should be laid parallel with the slope run, so that drainage is possible. Also note, that the deck must be stabilized by being attached to the building. There are several different options to attach the deck to the structure. We have installed several such decks. I recommend you take a look at our work. You can get a rough idea by watching the video below.
I am still new to the site and must have 15 posts before being allowed to post urls. Go to mandrroofing.ca and click on flat roofs in the blog categories.
M&R Roofing is offline
Old 12-07-2011, 02:28 PM   #11
Garrison Construction
Gary Garrison's Avatar
Use Hydro-Stop waterproofing membrane.
Gary Garrison is offline
New flat roof "ponding" medusa Roofing 67 12-12-2010 04:17 AM
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 11:09 AM
Flat roof over garage leaking under exterior walk out door IHI Roofing 18 05-30-2006 10:28 PM
Torch down(flat roof) leaks BAD...can you give advice ASAP? Detail Guy Roofing 21 01-16-2006 02:36 PM
Do You Need A New Roof ??? Perfect Roofing Roofing 0 02-10-2005 02:46 AM
