Cutting Lifts Of Metal Studs (2x6)
Old 10-10-2005, 01:13 AM   #1
old27's Avatar
Trade: Work
What do you guys suggest is the best system/ tool for cutting a large quantity of studs? thanks in advance.
-old
old27 is offline
Old 10-10-2005, 07:57 AM   #2
Crawdad's Avatar
Trade: Lawn Care
Re: Cutting Lifts Of Metal Studs (2x6)
Chop saw with a metal cutting blade, and a good set of ear muffs.
Set up a stop for cutting large numbers of studs the same length.
Rental places generally put a new blade on for each time a saw is rented, and if you're a good customer, they might let you have a pile of halfway used up blades.
(I haven't always been the lawn guy, I've disguised myself as a carpenter a few times)
Crawdad
Crawdad is offline
Old 10-10-2005, 05:06 PM   #3
mdshunk's Avatar
The slickest thing I've seen is a shear that has a die in it that matches the profile of the steel stud. Slide the stud in and pull the handle down. Takes 2 seconds and doesn't make any noise or sparks.
http://malco.malcoproducts.com/produ...all/src24a.asp
mdshunk is offline
Old 10-10-2005, 11:18 PM   #4
old27's Avatar
Trade: Work
Thanks MD and Craw for your input.
old27 is offline
Old 10-11-2005, 07:20 AM   #5
Crawdad's Avatar
Trade: Lawn Care
No noise or sparks? No fun!
Actually, that thing is slicker than snot on a doorknob.
Crawdad is offline
Old 10-11-2005, 10:21 AM   #6
kenvest's Avatar
Trade: carpenter
i've had good luck with a porta-band....not quite as fast (or loud) as the chop saw but this tool is overall more useful and worth buying if you don't already have one.....nice thread on it down in tool world...
good luck!
kenvest is offline
Old 10-14-2005, 09:24 PM   #7
DJC's Avatar
Trade: GC, Electrician
For quickness and quanity.....chop saw
DJC is offline
Old 10-16-2005, 01:35 AM   #8
Superintendent
ConcreteGuy's Avatar
Trade: Concrete Foundations and Flatwork
There's a reason successful commercial drywall contractors use a metal cutting chop-saw. It is to make me deaf and burn holes in my clothes.
Eh?
______________________________________________
A reasonable expectation becomes an assumption when it goes wrong.
ConcreteGuy is offline
Old 10-31-2005, 09:11 PM   #9
Metal Stud Framer
Zendik's Avatar
Trade: Commercial Construction, Metal Stud, Drywall & Acoustic Ceiling
Throw the entire bundle on a chop saw with an abrasive blade and cut away........
Zendik is offline
Old 10-31-2005, 09:25 PM   #10
Justanotherdumbdrywaller
boardslinger's Avatar
Trade: Wallsystems
This is what I do, so I have to agree with the majority and say chop saw, but if you have you can also use a gas power saw, like the saw's tile roofers use, with a metal blade, works just as well.
Bang it, Slam it, Screw it, Aaaaaaah Sheetrock.
boardslinger is offline
Old 11-01-2005, 02:24 PM   #11
Bob Kovacs's Avatar
Trade: Consultant
Order them precut from the supplier- that's the easiest way of all
Bob
Bob Kovacs is offline
cutting steel studs 25BRIAN General Discussion 28 05-22-2009 09:41 AM
Baseboard to Metal Studs? MHMConstruction Remodeling 17 06-03-2007 12:06 PM
Metal Studs Vs. Wood Studs Towatei & Co. Drywall 7 05-12-2007 11:03 PM
metal studs drywaller56 Carpentry 2 03-08-2006 08:12 AM
