Cracked Walls
Old 07-01-2009, 09:54 PM   #1
Paragon Home Re's Avatar
Trade: Home Renovations
Cracked Walls
Two years ago, I built a sunroom addition on a house. The floor joists are above ground and supported by a ledger board attached to the house and a beam which is supported by 3 metal posts with helical plates drilled six feet into the ground. Every winter there appears a 1/4" vertical crack in the wall above the sliding patio doors running up to the ceiling. The crack closes in the summer.
I'm pretty sure the foundation is not moving so I am wondering if there is just some movement in the wall where the patio doors are that is causing the crack to open. Could it be expansion and contraction of the wall frame doing this? Its a shed style roof and the crack appears on the side wall above where the patio door is.
Any ideas on either a cause or a solution?
Paragon Home Re is offline
Old 07-02-2009, 02:46 AM   #2
ronaldjeffccma's Avatar
Trade: -
Re: Cracked Walls
Hello, i think you will talk to a genesis engineer he solved your problem.
Ok!
ronaldjeffccma is offline
Old 07-06-2009, 08:25 PM   #3
72chevy4x4's Avatar
Re: Cracked Walls
how does a crack 'close in the summer'?
72chevy4x4 is offline
Old 07-06-2009, 09:07 PM   #4
LRG WoodCrafting
Leo G's Avatar
Re: Cracked Walls
Solution - Install crown molding.
Is the roof made from trusses? If yes, that is your issue. Not much you can do about it. There are building techniques to minimize this problem.
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
Old 07-06-2009, 09:37 PM   #5
JumboJack for president!
XanadooLTD's Avatar
Trade: Hilti walking billboard
Re: Cracked Walls
hulk hogan maybe slamming the doors?
XanadooLTD is offline
prepping cracked bathroom walls 72chevy4x4 Painting & Finish Work 8 03-26-2009 08:16 AM
Tall walls (2-storey walls) Zoltar Framing 21 03-11-2009 01:00 AM
here's a painting price list...... Jer44 General Discussion 9 02-17-2009 08:30 AM
Why Build ICF monsterconstruc Green Building 32 09-28-2008 11:48 PM
