Concrete Slab Control Joint.
Old 04-22-2008, 11:43 PM   #1
K2's Avatar
Ok I'm used to using a groover when it's wet or a saw when it's dry but today I saw a control joint that was hairline, like it was cut with some kind of laser. What was I looking at? Thanks!!
K2 is offline
Old 04-23-2008, 01:05 AM   #2
Re: Concrete Slab Control Joint.
Maybe a "cold joint"?
Just a construction joint
between two separate pours?
neolitic is offline
Old 04-23-2008, 07:52 PM   #3
CaliDesigns's Avatar
Maybe a blind seam or a softcut with a 1/16th inch blade
CaliDesigns is offline
Old 04-23-2008, 10:31 PM   #4
Tom R's Avatar
Cut your eyebrows, geezer . . .
Tom R is offline
Old 04-23-2008, 11:30 PM   #5
K2's Avatar
Yeah maybe blind seam but I'm not sure what that is....
I looked again at this slab and it looks like there may be something set before the pour and slightly below the surface. It just looks like hairline cracks, 10 ft apart, that are perfectly straight. ...
Of course in this part of the country pools are not real common so we don't get to see the fancy slab work. I was down in florida and saw some laced concrete and was thinking that laced is really nice but would probably not hold up to good in the "cooler" climates.
Anyway, I've done tons of control joints in my younger days and am always impressed when I see one better than mine.
K2 is offline
Old 04-23-2008, 11:42 PM   #6
K2's Avatar
You're the old guy around here and that Jersey accent makes it worse... I haven't been visiting down in the cellar because, I hate to say it , I got a job... I'll stop in on Nov 3 to decide who to vote for. I'll just vote opposite you. and of course opposite the big R.
K2 is offline
Old 04-23-2008, 11:47 PM   #7
Tom R's Avatar
Yah, - - I hate when my accent shoots clear across my keyboard . . .
Congrag on the job, - - just don't forget to trim that uni-brow . . .
Tom R is offline
Old 04-24-2008, 06:32 AM   #8
Tscarborough's Avatar
Probably something like this:
http://www.formakey.com/Index.asp?mode=NCCJ
Tscarborough is offline
Old 05-03-2008, 06:07 AM   #9
atlanta
yes.itsconcrete's Avatar
Trade: decorative conc. & conc. repairs
there're other names on the mkt, too,,, never lik'd stay-in-place for conc you could see,,, if the elevation's not 'zactly right, wind up w/little wave control jnts that look like hell to me & make it difficult to finish dec conc overlays.
yes.itsconcrete is offline
Old 05-14-2008, 10:11 AM   #10
themudman's Avatar
Trade: the mudman concrete const.
I saw guys up in oregon cut a groove in a garage floor with a groover, then fill it back in with cream during the finishing process. About a month later it would crack staight as an arrow up that groove line.
themudman is offline
Old 05-14-2008, 11:56 AM   #11
Tech support
gene dean's Avatar
Trade: 38 years concrete contractor, 16 years decorative, 8 years architectural overlays
formakey.com
You can also get this in a key way configuration. A little more of a pain but if installed properly, helps with the screed process. gene
Elite Crete of Indiana
Architectural Concrete Finishes
Info@elitecreteindiana.com
gene dean is offline
Old 05-14-2008, 03:53 PM   #12
atlanta
doesn't help me like 'em more,,, IF they were install'd at the correct elevation, that'd be different,,, driveway guys do not use lasers, tho ! ! !
in theory, there's no difference 'tween theory & practice,,, in practice, there is !
Help Installing Hardwood over old/new Concrete Slab Hages Flooring 7 06-04-2008 01:02 PM
Concrete Slab...Need to Tile Over It Tommy C Masonry 4 04-07-2008 08:18 PM
Question regarding concrete slab TennesseeBrian Concrete & Paving 5 01-06-2008 09:11 PM
Stone patio on a supported concrete slab. natural1 Masonry 3 11-16-2007 10:01 AM
Solution for VCT cracking @ control joint puzzledlog Flooring 2 05-16-2007 08:48 PM
