Trade: general contractor
Concrete Header
I am figuring a job cutting a hole through a 9" concrete wall in a church basement between the kitchen and community room.the wall is bearing the joists from the floor above {no roof weight}the joists span about 14' either way of the bearing wall. I will be opening a hole 10' wide and leaving 20" of concrete wall above it as a header.I don't feel comfortable with this as a header as it is an old wall and I doubt it has any rebar.Was thinking of using a large angle iron to help with the support so as not to loose any head room. I hate to cut any higher and add a real header because of issues with the suspended ceiling.Any thoughts as to the strength of this?
Re: Concrete Header
That's a hell of a wide opening to cut in with a header that you suspect has no rebar. Seems like you ought to really get your engineer to swing by and throw his eyeball on that.
Trade: underground
Re: Concrete Header
MD's right - get an engineer involved. Unreinforced concrete has very little tensile strength.
Fortunately I keep my feathers numbered for...for just such an emergency. -Foghorn Leghorn |
Re: Concrete Header
You have confirmed my suspicion. Worst case scenerio I could cut the concrete wall clear to the top and go back with an LVL for a header and build the wall back down.I would be able to remove suspended ceiling on each side of the wall to brace the joists up while cutting.Was just hopeing for an easier way! Oh well like they say, if it was easy anyone could do it!
#5 | |
Re: Concrete HeaderQuote:
| Fiber Optics in concrete countertops | 6stringmason | Concrete & Paving | 17 | 03-16-2011 05:49 PM |
| Staining concrete | ryan.s | Masonry | 12 | 03-05-2009 03:54 PM |
| Window header 2x6 framing | Atlantex | Framing | 20 | 11-06-2007 10:55 PM |
| Concrete home | denick | Concrete & Paving | 5 | 03-06-2007 04:32 PM |
