Commercial Partitions
Old 09-21-2008, 03:39 PM   #1
John Deere's Avatar
Hey guys, my framer disagrees with my method of framing partition walls in commercial tenant improvement applications. How do you guys normally secure the top channel of metal stud partition walls when there is an existing drop ceiling? I need to frame a partition wall that will span the entire width of the space (30'). The drop ceiling height is 9' and I simply wanted to secure the top channel to the ceiling grid. He does not think this will give the wall enough support.. I dont want to disassemble the drop ceiling. Any better suggestions?
John Deere is offline
Old 09-21-2008, 05:43 PM   #2
Ivinni's Avatar
Trade: High Rise Caulk and Insulation
Rewards Points: 250
Re: Commercial Partitions
You could try a 45 dgree kicker form the top of the wall (through the tile) up to the deck. Frame the wall 2 inches short of the ceiling grid, the run the rock to the grid in order to cover the sight of the kikers. Use a kicker every 10-15 ft..
The grid will not withstand the weight of the wall. Good luck.
its not going to get better with straps, or new footings or even aroma therapy.
Ivinni is offline
Old 09-21-2008, 06:27 PM   #3
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,659
Agreed. Especially if the tenant foolishly decides to hang anything with any weight to it on that wall. Commercial construction generally doesn't accomodate itself to underbuilding--at least, notg more than once.
Tinstaafl is offline
Old 09-21-2008, 07:41 PM   #4
Kgmz's Avatar
Are you installing this wall so to divide this space for 2 different tenants, etc.
If so, the wall needs to be a fire rated wall and stopping at the drop ceiling grid is not going to fly.
Kgmz is offline
Old 09-22-2008, 06:49 PM   #5
Mellison's Avatar
Trade: Home Improvement General Contractor
This sounds pretty ghetto to me.
Mellison is offline
Old 09-22-2008, 07:30 PM   #6
theworx's Avatar
Exactly, walls seperating different tenant spaces need to be fire rated from floor the the above deck. Our rules here require 2 layers of 5/8" on both side of the wall.
If you are just putting in partitions in a single tenants space - then attaching your top track to the grid is totally acceptable (it's the floor that supports the weight of the drywall). Make sure you screw the studs (not just crimp). Also, check the perimeter of the room to make sure the main tee's and at least every second cross is screwed to the wall - will eliminate any movement in the grid!!
theworx is offline
Old 09-24-2008, 11:22 PM   #7
matt grisham's Avatar
Trade: acoustical dry wall
Rewards Points: 75
Smile
We do intire buldings under grid framing. Except fire walls, Demizing wall. Fire exits
matt grisham is offline
Old 10-15-2008, 04:48 PM   #8
detroit687's Avatar
Trade: carpenter
Its called underpinning screw your top track of to the mains with type s or s-12 pan heads VERY common in commercial carpentry. If you hang in drops from the grid put extra heavier gauge hanger wires. Allso keep in mind that with acoustic caulk and acoustical insulation its very easy keep walls at certain decipal levels with this app. If installing new walls to grid where the tilles havent been dropped yet keep in mind that the weight of the tilles will tighten hanger wires and your ceilling will deflect so install your studs accordingly
detroit687 is offline
Old 10-15-2008, 06:00 PM   #9
General Contractor
Snow Man's Avatar
Trade: Construction Management
There is a man who knows his sh*t!
DECOSnowRemoval&IceControl
Serving Delaware County & Philadelphia Pa
610 457-9721
Snow Man is offline
Old 10-15-2008, 11:40 PM   #10
kgphoto's Avatar
Trade: Residential Remodeling
Rewards Points: 250
Code in LA will not allow attaching partition walls to the grid. It is OK to use them as temporary supports, but kickers need to be placed 4 feet on center to opposite sides of the wall for the entire length, then the attachment to the grid removed.
Check your local code.
kgphoto is offline
Old 10-23-2008, 10:00 AM   #11
Metal Stud Framer
Zendik's Avatar
Trade: Commercial Construction, Metal Stud, Drywall & Aco
Rewards Points: 152
Cali. and Oregon cannot attach to the grid for seismic reasons. Best way would be to kick off to the deck 45 degrees every 8ft.
Zendik is offline
Old 10-24-2008, 08:10 PM   #12
I eat sawdust.
Winchester's Avatar
Trade: Deck Design/Build
Rewards Points: 2,000
This brings up a good question, sorry if I hi-jacked. Someone I know wants to build a 10x10 office in the corner of a large area with high ceilings, but he only wants the walls to go up, say 10 feet high.
How would you support the 2 walls that you would have to build?
Winchester is offline
Old 10-25-2008, 12:41 PM   #13
Snobnd's Avatar
Trade: Remodeling 30+ yrs
Rewards Points: 1,658
Snow Man beat me to it ,,,,,detroit687 nailed it, I use J channel to keep the separation away from the grid for sheetrock & Tape.
A few kickers above won't hurt.
Snobnd is offline
Old 04-02-2009, 01:56 PM   #14
consolidatedbui's Avatar
Rewards Points: 25
a 30' wall will be plenty strong fastened to the ceiling with a few diagonal braces.. the j channel idea always looks like crap for me so we use zip strip.
spackle it with tiles in place, pull zip cord to reveal a perfect ceiling transition
consolidatedbui is offline
Commercial Pool Bid? TexasPoolPatrol Pool Construction & Enclosures 4 02-02-2009 02:27 PM
NJ "Impact Fee" on commercial projects?!?! cburke501 Business 12 08-28-2008 10:32 AM
commercial contract HUDSONVALLEYEXT Painting & Finish Work 1 08-21-2008 06:29 PM
Bidding Commercial Projects cburke501 Business 1 08-16-2008 07:19 AM
EPDM RUBBER pricing (commercial) tekwrytr Roofing 3 12-01-2007 08:33 PM
