Column Spacing On Beam
Old 04-04-2007, 06:48 PM   #1
When It Rains, It Pours..
highlife77's Avatar
Trade: Remodeling(Everything)
Im doing a complete gut out on 4 - 1500 sf units..only leaving one load bearing wall per unit.HO wants a 27' header installed with steal columns...Im thinking of using a 4"x12" Timber beam if I can get a full run...if not I will use 2- 2x12's..the beam will be exposed, but I have 4 units to do like this..3 jacks studs on each side of the beam ..the 2nd floor only supports the flat roof above but all that weight will be on the first floor, the basement has 6' 6x6 posts every 5'...the ceilings in the units are 9'9" what should I space my columns at? Any Ideas???Thanks.
"When It Rains, It Pours"....
highlife77 is offline
Old 04-04-2007, 07:01 PM   #2
reveivl's Avatar
Trade: Renovations
Re: Column Spacing On Beam
Whatever the engineer tells you to...
reveivl is offline
Old 04-04-2007, 09:28 PM   #3
Professional
In_Mexifornia's Avatar
Trade: Finish Carpentry
You could use an PSL. They make a 3 1/2" x 11 7/8" that will span 28', but you need someone(an engineer) to calculate the load to make sure that would even carry it. If it's exposed you might want to wrap it with something though to make it look better.
In_Mexifornia is offline
Old 04-04-2007, 10:59 PM   #4
Home Repair Specialist.co
hrscammisa's Avatar
Trade: carpentry
Try using LVL beams I have done a home here last year where the guy I was working with was not only the GC but the owner of the home 6500.sq ft this was when I first moved here. and the span on some of his beams that were load bearing for the second floor were 30ft plus he used two at a time with no problem. But like they are saying what are the drawings telling you to use dont listen to the HO
hrscammisa is offline
Old 04-05-2007, 01:28 PM   #5
AtlanticWBConst's Avatar
Check this company out:
http://www.metwood.com/products/truspan
FWIW - Great product. We have used it.
- Build Well -
AtlanticWBConst is offline
Old 04-05-2007, 06:41 PM   #6
highlife77's Avatar
well the blueprints are saying 2-2x12 but I'm trying to figure column spacing...I have an engneer coming out next week to stamp my prints. So hopefully I ll get it figured out with him...thanks for the info.
Beam Specs ophnurse Framing 19 10-02-2007 08:21 AM
Lally column footer depth Second Look Construction 12 04-01-2007 12:29 AM
flitch beam installation kweber General Discussion 4 02-04-2007 11:43 AM
Main beam sagging 1/2 inch? AllGoNoShow Construction 10 10-12-2006 08:20 PM
deck beam sizing and post spacing? diyerforever Decks & Fencing 5 05-10-2006 10:58 PM
