Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Construction
Old 06-28-2006, 07:33 PM   #1
Trade: builder
chimney flashing on standing seam roof
I am about to have my stone masons saw a reglet for the chimney flashing, how high up from the roof sheathing should the reglet be sawed?
At what angle should the reglet be sawed? Roof will be 1 1/2 standing seam.
What is the best material for the flashing? copper,lead,aluminum, or the steel roofing material?
Thanks,
Kermmonk in TN
kermmonk is offline   Reply With Quote
Old 06-28-2006, 07:58 PM   #2
Tscarborough's Avatar
Trade: masonry
It should be stepped (meaning the angle is 180 degrees, i.e. flat), at least 4 inches, preferably 8" above the roof line. The material only matters if it will be visible. If not, copper or SS will last the longest, but to avoid galvanic corrosion, it should probably be the same material as the roof.
Tscarborough is offline   Reply With Quote
Old 06-28-2006, 08:39 PM   #3
I cut 'em in at about 15 degrees . . .
Yeah, - - 4" absolute minimum . . .
Tom R is offline   Reply With Quote
Old 06-28-2006, 09:06 PM   #4
pro
Trade: ...
I agree with tom, far as your counter I would go with lead and either elastomeric or solarseal for caulk, will be very easy to peen the lead to conformity than trim even at your pan
Custom Decks & Carpentry LLC.
play
more play
raped ape
Originally Posted by nilscraft View Post
I'm doing a bid for a homeowners ass
Bone Saw is offline   Reply With Quote
Old 06-29-2006, 08:03 AM   #5
stop botherin' me!
Grumpy's Avatar
Trade: Roofing Siding Gutters Windows
I never do a straight flashing except at an ampron, at an incline it should be raggled, or stepped with the mortar joint. I also say 4" is minimum, but since we step with the mortar joint, it's usually a bit more than 4".
Why not just metal to match the roofing material? After all it is a metal roof. Steel SS roof = steel flashing IMO. Kynar SS roof = Kynar flashing etc...
-Grumpy
Chicago Gutters Chicago Roofing
Grumpy is offline   Reply With Quote
Old 06-29-2006, 08:34 PM   #6
Trade: builder
Hey guys thanks for the info!
Kermmonk
Flashing around a chimney Barry M Roofing 62 04-23-2007 11:40 PM
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 11:09 AM
Standing seam metal roof? kermmonk Roofing 1 08-14-2006 09:34 PM
Torch down(flat roof) leaks BAD...can you give advice ASAP? Detail Guy Roofing 21 01-16-2006 02:36 PM
Do You Need A New Roof ??? Perfect Roofing Roofing 0 02-10-2005 02:46 AM
