Caulking Copper - Construction - Contractor Talk
Caulking Copper
Old 09-13-2018, 03:42 PM   #1
Lettusbee's Avatar
Rewards Points: 2,898
Caulking Copper
I caulked a hose bib penetration with clear big stretch last year. Took it apart today and the clear big stretch is a beautiful aquamarine.
Something tells me that caulking isn't good for the copper.
What do you recommend for caulking copper penetrations through the wall?
Lettusbee is online now
Old 09-13-2018, 04:53 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 3,282
Re: Caulking Copper
i've seen 100% silicone spec'd out as caulk for copper.
i wouldn't be too alarmed at seeing that color as copper will do that on it's own if left exposed. usually why copper is called out to get that patina. fancy name for it is verdigris.
griz is offline
Lettusbee (09-13-2018)
Old 09-13-2018, 06:30 PM   #3
Lettusbee's Avatar
Re: Caulking Copper
Cleaned the caulking off the copper and it looks just fine, so your likely spot on. Just in this case it's the caulking that gets the verdigris.
I remember warnings from AAMA classes and JLC articles about certain caulks/sealants not reacting well with some metals.
Since I never work with coil stock or copper, I can't keep the rules straight in my head.
Old 09-13-2018, 08:19 PM   #4
Renaissance Man
superseal's Avatar
Rewards Points: 5,598
Re: Caulking Copper
I always use Quad in bronze...in no time the patina brings them together...Typical for me is up against brick/copper and high up but the match is good once the copper browns out, no discoloration and it's a tenacious, long lasting seal.
Caulking copper-burns-project-444.jpg   Caulking copper-img_2690a.jpg   Caulking copper-burns-project-460.jpg
supersealconstruction.com
superseal is offline
The Following 2 Users Say Thank You to superseal For This Useful Post:
Lettusbee (09-13-2018), Rio (09-14-2018)
Copper Pipe Bender Smokin Plumbing 21 12-07-2014 11:57 PM
Copper roofing Trimac Roofing 6 07-07-2014 02:17 PM
Pinhole leaks in copper pipe FStephenMasek Plumbing 16 11-08-2012 07:59 AM
Copper Industry Launches New DIY Architectural and Plumbing Videos Grumpy Roofing 0 06-03-2011 09:32 AM
Bending copper Morning Wood General Discussion 9 11-01-2010 08:17 AM
