Cant Find Waterproofing Contractor
Old 05-03-2007, 07:20 AM   #1
Designing YourImagination
TurnkeyConst's Avatar
Trade: Custom Remodeling
Was wondering if anyone can help me out. I have called and called to find someone to waterproof the exterior of a 3' block wall which I will backfill against. Cant find anyone to give me an estimate. What can I buy to do it myself? the wall is 3'x36'. Need to submit a bid on the job ASAP anyone know where to get the material and about what it takes to install it? Thanks
im in Greensboro NC
TurnkeyConst is offline
Old 05-03-2007, 08:10 AM   #2
Same Old's Avatar
Trade: Residential General
Re: Cant Find Waterproofing Contractor
You're not looking hard enough. Waterproofers charge by the square foot for typical applications and can give you a quote on the phone. Most will have a minimum you might run into for this. Generally $300-400. You might be better off getting some polywall and rolling it on yourself.
Same Old is offline
Old 05-03-2007, 09:05 AM   #3
concretemasonry's Avatar
Trade: Masonry consultant
Do you want to waterproof or damp proof the wall?
Damp proofers are everywhere, but advertising costs more than the equipment. For damp proofing, some black stuff (color looks impressive) and some poly will satisfy someone for a while. - Anyone can do it.
Dick
concretemasonry is offline
Old 05-03-2007, 11:37 AM   #4
tgeb's Avatar
This is what we use,
http://www.seaboardasphalt.com/LN-16_Data.htm
LN-16 is the formulation you need.
HD and Lowes will usually have LN-4 which looks pretty much the same but is not waterproof.
You should be able to find this at nearly any good builders supply.
A can of this stuff, a paint roller, and some clothes you want to throw away when finished are all you need.
www.gebcon.com
tgeb is online now
Old 05-03-2007, 05:46 PM   #5
denick's Avatar
Just a note on Waterproofing.
If this is for a dwelling especially residential be careful. Most contractors insurance policies exclude doing any kind of damp or waterproofing. I know contractors that have been dropped for no other reason than applying thoro seal. The mold issue to them is huge. If this is a written requirement in plans think twice.
We only apply materials spec'd by someone else. We do not ever use the words damp/water- proofing even in conversation. foundation coating is the term we use if we would entertain doing the work. Builders should not put it in their spec's either.
Nick
"Every day I remind myself that my inner and outer life are based on the labors of other men, living and dead, and that I must exert myself in order to give in the same measure as I have received and am still receiving" Albert Einstein
denick is offline
American Contractor Tutor dcc Help Wanted or Looking For Work 2 05-28-2008 12:49 PM
Florida Roofing Contractor Seeking GC Qualifier roofinrose General Discussion 4 10-18-2006 10:11 PM
Contractor or Government Joke? Highland61 Off Topic (Non Trade) 8 07-27-2006 09:00 PM
Paint contractor in Atlanta needed donb1959 Help Wanted or Looking For Work 0 03-30-2006 09:46 PM
