Can Anyone Here Explain Why This Worked?
Old 05-22-2009, 10:02 PM   #1
stp57's Avatar
Trade: carpenter/ handyman
I was drilling 3/16"x2" holes in 2 week old concrete for 1/4" Tapcon screws last week for a HO. My roto hammer didn't have a problem making the holes, but when I tried using the same tool to put the screws in (like I usually do with no problem), they would only go half way in & lock up. I drilled the holes deeper & vacuumed the holes out, but still the screws only went halfway. I even tried my impact driver to no avail. I didn't pull my hammer drill out of the truck to try it because I was already embarrassed enough that the HO was witnessing all of this.
The kick is, that when I went to get a fresh battery the HO dragged out his Riobi cordless drill & screwed all of the Tapcons in while in reverse! Can anyone here explain why this happened? The HO swears that the screws have left handed threads? All I know is that my industrial tools appear to have gotten whupped by a Riobi drill & not even a hammer drill!
Steve
stp57 is offline
Old 05-22-2009, 11:58 PM   #2
dkillianjr's Avatar
Re: Can Anyone Here Explain Why This Worked?
Sounds to me like you may have gotten a bad batch of tapcons Either that or the HO had them made with reverse threads to play a joke on you
dkillianjr is offline
Old 05-22-2009, 11:59 PM   #3
Jordy3738's Avatar
Trade: Cabinetry
A left handed thread on a tapcon?
Hmnn, now there's a totally new concept for discussion. I have to really wonder if the screws have any holding strength after he ran them in backward.
Jordy3738 is offline
Old 05-23-2009, 01:37 AM   #4
solar guy
naptown CR's Avatar
Trade: solar contracting
Thats f'd up there dude
naptown CR is offline
Old 05-23-2009, 02:33 AM   #5
Coming out of the closet
ClosetPro's Avatar
Trade: Closet Design-Install-Remodel
Maybe you were upside down.
ClosetPro is offline
Old 05-23-2009, 02:47 AM   #6
Smart phone? Scan me!
nEighter's Avatar
Trade: Painting/Framing/Drywall
No man... it was opposite day.. jeeeeze...
nEighter is offline
Old 05-23-2009, 03:40 AM   #7
Crash Test Dummy
ChainsawCharlie's Avatar
Trade: Landscaping
that's R-Y-O-B-I.
ChainsawCharlie is offline
Old 05-23-2009, 08:18 AM   #8
stp57's Avatar
Thanks Charlie,
Freudian slip, I'm sure.
I've got to go back there today. This guy is building an outside grill island. He is working with metal studs because of the heat that the grill & turkey fryer burner produce. He has a swimming pool nearby & I'm sure that the chemicals will play havoc on the studs. I haven't worked with metal studs before (the HO hasn't either) & I can't see how something framed in this stuff & covered with Hardi-backer & then slate will hold all of this weight?
Steve
stp57 is offline
Old 05-23-2009, 08:25 AM   #9
KemoSabe
loneframer's Avatar
Originally Posted by stp57 View Post
Thanks Charlie,
Steve
Metal studs are made in different gauges. The HO needs to get a load bearing stud.
loneframer is offline
Old 05-23-2009, 08:53 AM   #10
When he ran 'em in backwards
he just reamed out the hole
in that green concrete.
I'll bet the withdrawal would
be pretty easy, but they will be
okay in shear.
Light gauge studs wouldn't
last very long likethat around here.
neolitic is offline
Old 05-25-2009, 06:55 PM   #11
Inner10's Avatar
Trade: Control Systems
He reamed out the hole, like neolitic said.
The tapcon bit was intended for block not solid concrete, you need a bit of a slightly different tolerance or you'l keep loosing your head on the long ones; sometimes green can be more of a pain then aged concrete.
Inner10 is offline
The Following User Says Thank You to Inner10 For This Useful Post:
sparehair (05-26-2009)
Old 05-26-2009, 10:56 PM   #12
Tom R's Avatar
Not sure exactly what your exact application was, - - but tapcons will normally thread comfortably about 1" to 1 1/4" deep, - - and as was mentioned above, - - even less in solid concrete, - - probably more like 3/4".
Funny story, though, - - I bet the homeowner will definitely love tellin' that one!! . . .
"So then I tell's the contractor, - - here, try my Reversin'-Ryobi"!! . . .
Tom R is offline
Old 05-27-2009, 08:27 AM   #13
stp57's Avatar
Tom,
Thanks, I believe that had to have been the problem. The HO only had 2 3/4" Tapcon's to hold down metal studs. Too much penetration. Lesson learned.
Steve
stp57 is offline
Old 05-27-2009, 07:15 PM   #14
ampman
ampman's Avatar
Trade: providing pathways for electrons and protons
never had much luck with tapcons probaly my fault
an army of sheep lead by a lion will defeat an army of lions lead by a sheep
ampman is offline
Old 05-27-2009, 10:57 PM   #15
Inner10's Avatar
The lesson you should be learning is that the incorrect bit was used, or incorrect method. I've run 3 1/2" into both ancient concrete and green concrete without problems. As mentioned use the correct bit tolerance if its block of concrete (I use Hilti bits).
Overdrill the holes, the longer the hole the greater the additional depth is required. 1/4" is suggested but I typically mark my depth gauge or bit about 1/2" extra. Run the bit up and down to clear the holes.
Sucking out pin holes with gravity working against you can be difficult, get a can of duster(close your eyes its gets dusty!) or a blow-bulb.
If your drill begins to bind or the impact is anviling and not turning the screw much, back it out and ream the hole out again, loosing your head is depressing.
...bottom line is its a great excuse to get your wife to allow you to buy a powder actuated gun!
Inner10 is offline
Old 05-28-2009, 07:59 AM   #16
Tom R's Avatar
Or, do like I do, - - just go ahead and purchase it and when you get home say "look what you got me for my birthday"!!
Tom R is offline
Old 05-28-2009, 08:48 AM   #17
Inner10's Avatar
After all this posting I just figured it out!
Yet....
Inner10 is offline
Old 05-29-2009, 09:31 PM   #18
stp57's Avatar
Yet....
I set my depth gauge on my roto hammer to at least 3/4" over the screw length. I just typed in the wrong measurement. Remember, the HO screwed them all the way in reverse with his Ryobi, so the hole depth was not an issue.
That powder actuated gun sounds nice.
Steve
stp57 is offline
Old 06-01-2009, 12:43 AM   #19
Blackcloud's Avatar
Trade: Construction management/General contractor
why not just use hilti pins, or a ramset to shoot down the metal track?
Blackcloud is offline
Old 07-10-2009, 12:59 PM   #20
RumseySupply's Avatar
Trade: Rebar and lumber by the truck
funny sh!t
RumseySupply is offline
Please explain Prevailing Wage orson Business 13 05-07-2009 09:33 PM
House's Ive worked on. matthewcims Construction Picture Post 11 04-05-2009 02:01 PM
Non-conforming breakers - please explain? DetailHandyman Electrical 3 02-03-2009 07:39 PM
Yellow pages... has it worked for you, what did you do? will575 Marketing & Sales 10 12-03-2008 11:33 PM
For Those Who've Worked On Projects For Their Local Government.... CF Construction Marketing & Sales 9 11-24-2008 10:26 PM
