Building A Gas Fire Pit
Old 06-30-2004, 05:41 PM   #1
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
I will be building a gas fire pit for my deck. I figure I have two possible was to go.
The first is to get a new section of cement sewer pipe about 36 inches wide and cut a 18 inch piece of it off. Lay that on the deck and mortar rock veneer to it and create a flagstone ledge on top. Pros is it would be round, and look really nice. Cons is getting one and moving such a heavy thing somewhere to cut it.
The 2nd way is to build a octagon fire pit out of metal studs and cement board then veneer it with rock and create a flagstone ledge on top. Pros - much easier to do. Cons - won't be as pretty as a round one.
Question 1 - I don't think the standard non-load bearing metal studs made from 25 guage will be strong enough. Not sure if they make stronger ones or where to get them?
Question 2 - anybody else got any ideas on who to build one other then the ways I came up with? Gotta be cheap.
Mike Finley is offline
Old 07-04-2004, 05:30 PM   #2
ABA Const's Avatar
Send a message via Yahoo to ABA Const
Re: Building A Gas Fire Pit
or you could have a metal shop fab you a circle with angle iron and then you can line it with copper sheet metal and put flagstone on the edges. or use the same octogon idea but have it fabbed out of angle and then then skin it with rock veneer, i do like the 36" sewer pipe idea, but it would be a bear to move around and it would be a matter of how much room you would have to get it into your deck.
ABA Const is offline
Old 07-29-2004, 09:58 AM   #3
Chief Toilet Mover
Well, it turns out our county won't allow any custom gas fire pits now. So I have to resort to plan B and buy a premade one. Had the gas lines installed and am waiting for the inspection so I can get on with this!
Old 09-20-2009, 02:52 PM   #4
aaronwilliams12's Avatar
If you want to build a cheap pit why don't you use rock and cement?
Source for the best Gel Fire Bowls.
aaronwilliams12 is offline
Old 09-20-2009, 03:05 PM   #5
Its all ball bearings
angus242's Avatar
Trade: Tile
HOW HIGH ARE YOU?
5 year old thread
And if you even bothered to read it, he COULDN'T build a custom one.
Angus
L+M+O+P=Chttp://www.millan.net/minimations/smileys/einstein3.gif
"Promise only what you can deliver. Then deliver more than you promise"
angus242 is offline
Old 09-20-2009, 04:54 PM   #6
Project Manager/Carpenter
TBFGhost's Avatar
Trade: Carpentry/Reno
I make the mistake of bringing back old posts all the time. At least it shows he is doing searches rather then just asking the same question over again....
TBFGhost is offline
Old 09-20-2009, 05:09 PM   #7
dayexco's Avatar
get ahold of a cast iron sewer manhole frame from like this pic....this is at my house, they're 9" tall, don't rust, warp, distort....works great,
dayexco is offline
Old 09-20-2009, 05:10 PM   #8
dayexco's Avatar
geesus, and then i catch the 5 yr old thingie....neva mind
dayexco is offline
Need help with a shocking outside waterspout Badoish Electrical 23 12-27-2008 04:18 PM
Concrete fire pit ronald owen jr Masonry 14 08-07-2007 10:24 PM
Fire rating lathe and plaster ceiling adianz Construction 4 04-14-2007 07:02 AM
Fire Escapes skylands Construction 4 03-09-2007 08:22 PM
