Building A Dock
Old 05-01-2011, 08:36 AM   #1
CT122's Avatar
Trade: residential new and remolding
Building A Dock
Iíve been asked to bid building a dock. 8 x 16. We normally do
New construction but with the slow down this is a jobÖ Is there any
Trusted sites that would show the plans and method for sinking post ect.
The dock is on a pond water is about 5 ft
Thanks CT
CT122 is offline
Old 05-01-2011, 12:20 PM   #2
SuperiorHIP's Avatar
Trade: Home Improvement Contractor
Rewards Points: 1,326
Re: Building A Dock
Saw a guy doing them a few weeks ago with a bobcat.
We just finished doing a deck modification over the water. Homeowner said the guy took a 55 gallon drum with the top and bottom cut out, sank it in the water (not very deep), pumped the water out, dug it out with a post hole digger and sank the post.
SuperiorHIP is online now
Old 05-01-2011, 12:52 PM   #3
peteypablo's Avatar
Trade: Window cleaning
Re: Building A Dock
I'd recommend having it designed by an engineer qualified to do them. The consistency and content of the dirt (mud) will ultimately determine how deep you need to go. If you don't go deep enough you risk having the dock move or detach from the post and then possibly sink. If it's a floating dock though I suppose that would change things. Either way, don't under estimate the likelihood of problems arising with it down the road if it's not done right or the liability to which you are exposed should anything happen.
peteypablo is offline
Old 05-01-2011, 01:07 PM   #4
Painting & Remodeling
JHC's Avatar
Rewards Points: 516
Re: Building A Dock
I have built a few when I was younger working for someone who only did docks and piers. We sank pilings with a water pump. Hose was attached to a long piece of pvc, and a barge that had a hoist that would stand the piling.
Just put the piling on the bottom and the hose beside it, and turn the pump on. Make sure it sinks plumb the water does the rest.
JHC is offline
Old 05-01-2011, 03:36 PM   #5
I eat sawdust.
Winchester's Avatar
Trade: Deck Design/Build
Rewards Points: 2,000
Re: Building A Dock
get someone with a barge who does the piles. then build your dock.
Winchester is offline
Old 05-01-2011, 04:33 PM   #6
TheBuildingFirm's Avatar
Trade: Fuster Cluck Creator
Rewards Points: 198
Send a message via MSN to TheBuildingFirm
Re: Building A Dock
That might be a little overkill for a dock for a pond.
Why not just use a floating dock?
TheBuildingFirm is offline
Old 05-01-2011, 04:54 PM   #7
JHC's Avatar
Rewards Points: 516
Re: Building A Dock
I have seen guys do them by just wading out to sink the posts. Have to wait for low tide.
JHC is offline
Old 05-01-2011, 06:34 PM   #8
SSC's Avatar
Trade: Interior Remodeling Specialists
Re: Building A Dock
what are you going to attach it to ?
The Finest in Interior Renovations
SSC is offline
Old 05-01-2011, 07:14 PM   #9
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 3,496
Re: Building A Dock
Everyone around here is nothing more then helical posts that screw into the bottom of the lake or pond. bolt your cross braces on and frame it in sections that are easy to remove if so desired.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Paulie (05-01-2011)
Old 05-01-2011, 08:07 PM   #10
Grand Rapids Remodeling
Paulie's Avatar
Rewards Points: 2,052
Re: Building A Dock
Depends on where your at. Up here docks get brought in for the winter, ice is a VERY powerful force. My dock is just poles with feet.
By the way, many lakes have strict rules and regs about length and size of docks.
Paulie is offline
Old 05-01-2011, 08:34 PM   #11
Chief Reporter of Spam
Tech Dawg's Avatar
Trade: Kitchen and Bathroom Remodeling
Rewards Points: 1,280
Re: Building A Dock
I built a dock a few years back... I was having problems finding something to attach the drums with so I went to the local firehouse and they gave me some leftover firehose. Worked great!
Todd
Alone Eagle Remodeling, LLC
Tech Dawg is offline
Old 05-02-2011, 01:18 AM   #12
I eat sawdust.
Winchester's Avatar
Re: Building A Dock
i missed the pond part.
in that case just build a floating dock with concrete-filled 5gal buckets for anchors, it's not going to go anywhere
edit: found a pic of an anchored dock from fisheries & oceans canada
The Following User Says Thank You to Winchester For This Useful Post:
robert c1 (05-02-2011)
Old 05-02-2011, 07:49 AM   #13
nailit69's Avatar
Trade: Contractor/PM/Designer
Rewards Points: 150
Re: Building A Dock
That is the method I use, I live on a powerboat friendly lake w/wake boats galore so my dock takes a pounding. I did 2-5gal buckets of concrete for ea. corner and it works well.
nailit69 is offline
Old 05-02-2011, 09:02 AM   #14
CT122's Avatar
Re: Building A Dock
Thanks for info. We are building on a private lake in a golf course community. The helical post sounds like a possibility will have to research. Thanks again..
CT122 is offline
Old 08-13-2011, 11:43 AM   #15
BradingCon's Avatar
Rewards Points: 740
Re: Building A Dock
I know this is a little dated but I am now gonna built a dock for my pond and this thread caught my eye. One other method that I read somewhere was to put 12" pvc into the ground/mud, dip out the excess water in the pvc, set a 6x6 in the pvc and set the post in cement. You would do this for each post that you have to set depending on the size of your dock. I am considering doing this and am curious of everyone's opinion of this method. This may be a viable option for the OP as well.
Note: My pond is only about 5 foot deep where I would be putting the posts.
BradingCon is offline
Building walls on top of one another brothergrimey Framing 4 01-11-2013 10:56 AM
Building inspector wth??? insane Masonry 26 07-20-2010 11:33 PM
Commercial Building Renovation Questions cacwgrlc General Discussion 13 11-22-2008 03:37 PM
??? Whats the best way to spread the news about your company? jmgrahamjr Marketing & Sales 21 06-24-2008 03:46 AM
Certified Green Building Professional Training CatAlii Green Building 6 05-11-2008 03:20 PM
