Bridging For Above Grade Concrete Walls
Old 11-21-2005, 12:39 PM   #1
ETHICS05's Avatar
Trade: FLORIDA CERTIFIED RESIDENTIAL CONTRACTOR
(South Florida Construction)
I will be using an above grade concrete wall product called Epic Walls out of Orlando, FL (franchaise subsidiary of Superior Walls known nationwide I believe) for the first time. These walls will be taking the place of the traditional CMU concrete block walls and tie beam.
Question: I'm looking for a proper product (steel, or concrete, or other?) that is cost effective and will take the place of the traditional tie beam when used to bridge the span between front entry columns for example and have proper load capabilities needed to support roof trusses. The span between the front entry columns for example is between 7' and 9'. This is for residential single family homes.
I'd be happy to forward a picture of how the columns and tie beam with the traditional method look if that is helpful.
The walls themselves do not need a tie beam - trusses sit right on top of the walls. The Epic Walls are 6" wide.
Due to the "block shortage" some of us are experimenting with new products -new to us.
Thanks a lot! Feel free to send me an e-mail if you like to SAEhlers@swfla.rr.com.
ETHICS05 is offline
Old 11-21-2005, 12:43 PM   #2
Custom Builder
Glasshousebltr's Avatar
Re: Bridging For Above Grade Concrete Walls
I think a pic would help out here. Or at least a floor plan.
Something anyway.
Bob
Bob
Glasshousebltr is offline
Block Walls DaHammer Masonry 29 03-06-2009 07:11 PM
concrete walls finishing mjay Masonry 2 03-05-2009 03:36 PM
Looking for Mason in Winston Salem NC also someone who pours concrete walls w/ rebar TurnkeyConst Help Wanted or Looking For Work 1 12-13-2007 07:54 PM
Non-retaining concrete walls calypso Masonry 10 07-23-2007 08:55 PM
5" pored concrete slab on grade? Nac Masonry 1 04-25-2006 07:53 PM
