Can't Post
Trade: Construction
Brick Veneer On Steel Angle Iron
I am trying to add a brick veneer to my addition that I am building. In lieu of making a footing 30 inches for the brick, I was going to attach angle iron to the structure and start laying the brick on that. What does it mean that the angle has to be bolted to double studs? I was just going to bolt to my rim joist.
Here is what the code says: 1). R703.7.2.1 Support by a steel angle: The minimum size for steel angle support is 6 X 4 X 5/16 thick. This angle support shall be bolted to double studs by two 7/16 X 4 inch lag bolts. The double stud support shall be placed on 16 inch centers. Flashing and weep holes are required at the bottom of the steel angle. The maximum height of the veneer supported in this fashion is 12 feet 8 inches. A construction joint is required between this veneer and the veneer that bears directly on the concrete foundation. |
Trade: Consultant
Re: Brick Veneer On Steel Angle Iron
It means that you can't just bolt it to the rim joist- they want enough meat behind the angle to allow the lags to get a 3" or more bite into lumber- not the 1 1/2" you'd get from the rim joist.
Bob |
Is there some reason you're not bolting to the concrete at or slightly below grade level?
Trade: Masonry consultant
Why not just lay 4" concrete block on the footing and come up the 30" to grade and then switch to brick? The veneer is not structural and can sit on the footing.
Did I miss something obvious?
Dick Engineer, designer and consultant recently active domestically and internationally on construction and design in about 35 countries. |
Can't Post
Trade: Construction
basically i have the a concrete slab. I have added sills and laid my joists. So I do not have room on the slab to start a layer of brick,I do not feel like digging down 30" and laying concrete so I am going to use angle. I could bolt to the existing slab but it seems that every 16" is ridiculous for a 3' brick veneer and 5/16" angle is excessive.
any ideas? |
Have tried to talk to the code official? There may be better options, such as bolying into the edge of the slab.
Codes are meant to protect you from yourself in many instances. They are also meant for future owners that do not want to be mislead. Bolting at 16" is not excessive considering the weight and the shear strength of those bolts in concrete. You will be attaching wall ties for horizontal restraint closer. The angle even seems a little flimsy.
Trade: Mason
Build it right and cry once.
Dig down, drill pins, pour concrete, never worry about it again. |
#8 | |
Trade: masonry
Re: Brick Veneer On Steel Angle IronQuote:
i dont know how many times i have had ppl come to me and say,"i want to brick my house,but i dont think i have a brick ledge."i say ok,we will need to pour one.its not that hard.do it right the first time.
life is short,do your masonry naked!! http://ok.local.yahoo.biz/knabemasonry/index.html |
#9 | |
Trade: Nail bender
#10 | |
Trade: Building
| Brick veneer vs solid masonry | sean mccormack | Masonry | 16 | 04-23-2011 05:15 PM |
| brick veneer? | sandyman720 | Masonry | 6 | 05-02-2008 04:32 PM |
| Brick Veneer support over large opening. | Atlantex | Masonry | 8 | 08-14-2007 12:02 AM |
| Advice on mounting Steel angle irons. | turbomason | Masonry | 12 | 03-04-2007 12:47 AM |
| Brick Veneer Chimney w/ Factory Insert | rhomfeld | Carpentry | 6 | 09-15-2006 09:23 PM |
