Blueprint Reading
Can anybody recommend a good book to get up to speed on reading blueprints? Any online sources for learning.
thanks, Bruce |
Back from the dead...
Trade: Paperhanger/Painter
Re: Blueprint Reading |
And for Pete's sake... if there's a symbol or code on a set of prints for the area in which you are working that you don't understand, please ask someone. Most of those seemingly insignificant symbols or codes can be very, very important. Better to look "dumb" for 2 minutes asking someone than having to correct an expensive omission for hours, days, or weeks.
Some more free advice... read the spec sheet or spec book thoroughly too. Some of the oddest, most unusual, strangest, and expensive stuff in contained only in the specs and not on the print itself. Read the prints for the other trades too. Some of the things that are detailed on the prints of the other trades may well (and often does) pertain to you too. Last edited by mdshunk; 10-26-2005 at 08:15 PM. |
#4 | |
Priced In
Trade: Exiled For Life
Re: Blueprint ReadingQuote:
What do you mean they have to run wire through that wall. (pertaining too a double sheer wall) Tonkadad here is another site with alot of books on construction craftsman-book.com |
Custom Builder
Sorry Mrs Jones, but we need to run the double lammy through the car windows.
Bob
Bob |
#6 | |
#7 | |
Priced In
I do. I worked for this guy last summer that did that. The inspector was pissed they like to see the skeleton before it is covered. I had to do all this stuff and pull some strings to get it to pass. Now I don't know why I did it. Hell I try and tell the super you can use 3/4" ply instead of the double shear wall. I don't like sheeting it twice. |
Thanks for all of the help.
Trade: architect
The strength of a nailed plywood and stud sheer wall is determined essentially by the number, size, and type of nails that can fit around the perimeter of the panels. Therefore, adding another panel to make a double-sided shear wall effectively doubles its strength. Thickening the plywood is not as effective since the panels are expected to "unzip" along the perimeter edges before the plywood fails in shear.
Red Vector ( http://www.redvector.com/ ) has online courses for contractors: http://www.redvector.com/web_store/a...se.asp?id=1104 Last edited by mighty anvil; 11-03-2005 at 03:03 PM. |
Trade: PM
Being up here in colonial New England, we sometime build log cabins. Fella better read the plans cause carving a new chase through solid log walls can make a person cry. Or result in some suspiciously dark rooms.
About the question, pick up copy of Architectural Graphic Standards - if you really want to know drawings. It's spendy ($500), but even the edition from a couple years ago will give you a pretty functional idea of things, and they're usually on sale on Amazon. |
#11 | |
Carpe Diem
Trade: Remodeling/ General Contractor
wow I'm lost
#12 | |
Priced In
ps Don't go crying to the mod again it's unbecoming and a serious chink in your armor. |
Priced In
One more thing what does 3" perimeter nailing do on two sides I'll bet $100,000 that the whole wall will fail because of over nailing even with 3x (not hacky double stud b.s.) material on the vertical edges.
#14 | |
Bah Humbug!
For example I am not a plumber or electrician but I have to look at their specs and their sections of the prints to know where theya re to place penetrations in my roofs. Also as you said in the specifications you can find some of the weirdest oddest most poorly written specs you could imagine. Just weird stuff that makes me scratch my head. |
#15 | |
No real need to reply, - - I'd rather you just 'ponder' it. Thanks.
http://www.tr-built.com |
#16 | |
Priced In
What are you talking about? What free advice? I have had the paper work in my hands Engineer stamp included. And he try's and say different again. Sorry but I am not going to be pushed around by some guy that is a architect for backwoods America. |
#17 | |
Trade: plumbing and heating
#18 | |
The inherent value of this site is the myriad of opinions from all 'walks', - - the vast knowledge comes from no one person, - - but from the sum of 'all', - - that would include (hopefully), me, you, and HIM. The 'free advice' statement comes from my many experiences with his 'wealth of knowledge' on another site, - - you may not be so aware of it, - - because he's barely even been given a chance on this site. P.S. Didn't know Boston had a 'backwoods'!!
#19 |
Trade: architect
Perhaps I didn't expain it properly.
When a conventional plywood or OSB sheathed wall (with maximum nails/screws and glue) is not long enough to provide the required lateral bracing and a double-sided design is inconvenient, it is necessary to further increase the strength of the perimeter attachment of the panels and the connection to the foundation. Increasing the thickness of the panel would only add bracing strength if it allowed for greater nail/screw placement and I have never seen evidence of that although I can see a definite benefit in compensating for overdriven nails which is a common and serious problem with nail guns. Whatever the panel thickness, greater perimeter attachment is usually provided by using wider vertical members (3x studs) which allows greater staggering of the nail/screws. Additional bolts are usually added to transfer the greater forces to the foundation. Another way to provide greater bracing in a limited wall length is to use a factory built unit like Simpson's Strong-Wall which reinforces the edges of a 15/32" thick OSB panel with steel nailing strips and provides 7/8" hold-down bolts. Even though these prefabricated units provide double or even triple the shear force of conventional walls of the same size, the 1/2" thick OSB panel is not overstresed. http://www.strongtie.com/products/st.../standard.html Here is a good explanation of lateral bracing methods for homes designed to comply with the IRC. It includes the IRC allowed alternate short shear wall design where 3/8" plywood is allowed. http://www.co.thurston.wa.us/permitt...%20Bracing.pdf JustaFramer: The suggestion that a single sided shear wall using 3/4” plywood is equivalent to a double sided shear wall using 1/2” plywood is incorrect and it seemed important to inform the members here of that fact and to explain why. If you are feeling pushed around perhaps you should think twice before making statements on issues about which you have limited knowledge or, alternatively, toughen up about having them corrected and about having your personal insults reported to the administrator. If this kind of 1&2 family dwelling design information is somehow outside of, or in conflict with, the purpose of the Contractor Talk forum, please ask the administrator to let me know and I will stick to other forums where it is welcomed. Last edited by mighty anvil; 11-05-2005 at 11:37 AM. |
#20 | |
Priced In
Again I know the a GC that has engineering for the 3/4" ply so off
| Summer Reading | Terrence | General Discussion | 13 | 06-10-2007 01:41 AM |
| biue print reading | RAZOR BLADE | Construction | 13 | 01-16-2007 09:15 AM |
| Few questions about blueprint reading and pile caps | toni | Excavation & Site Work | 5 | 09-07-2006 07:02 AM |
| reading plans | Wensdy | Drywall | 3 | 08-30-2006 08:40 PM |
| invaluable reading | GMW | Business | 5 | 12-23-2005 05:12 PM |
