Which Bit To Use Through....
Old 06-03-2009, 07:09 AM   #1
Warmsmeallup's Avatar
Trade: Sales/Distribution/Installation of low or line voltage radiant heating and snow melting systems
We have to drill 16 holes, 1" x 16" deep. It a roof that is (2) 3/4" ply's, then 10" of air then 4" of concrete over corregated metal. A total of 16". How would you guys best accomplish this ?
We have 22" concrete bits for our Milwaukee demo hammer drill but I'm afraid to destroy the bit when we hit the metal.
Warmsmeallup is offline
Old 06-03-2009, 08:06 AM   #2
CypertJ's Avatar
Trade: Carpentry, General Contractor,
Re: Which Bit To Use Through....
start out with your 1" spade for the wood, drill the concrete with the 1" sds, you should be able to hear the difference when you first hit metal, stop there and move to the next hole, repeat until you have all 10 hole punched in the concrete, then come back with something more appropriate for the metal
CypertJ is offline
Old 06-03-2009, 08:17 AM   #3
If the "concrete" was always
a roof deck, it's most likely
light weight.
You might just get away
with a couple of cheap
twist bits.
It's not like drilling a slab
with regular aggregate.
neolitic is offline
Old 06-03-2009, 09:26 AM   #4
light weight.
Good point. It's new home, new pour as well so I'll check with the GC to be sure and try the twist first. Thanks!
Old 06-03-2009, 01:14 PM   #5
Lack Of All Trades
Darwin's Avatar
Trade: Professional handyman services
I would use the longest, strongest bit money can buy. The 10" of air will be your hardest part to drill through. Good luck
Darwin is offline
Old 06-03-2009, 02:24 PM   #6
framer
steves's Avatar
Trade: framing
Your hammer drill bits will go thru that no problem no dammage.
We do it all the time on elevated slabs
steves is offline
Old 06-06-2009, 08:15 AM   #7
TxElectrician's Avatar
Trade: Electrical
At the least it will be the hardest part to keep the bit straight in.
TxElectrician is offline
Old 06-15-2009, 09:06 PM   #8
KyleVH's Avatar
Trade: Commerical construction, mainly dealing with Steel
A Hilti SDS or SDS max bit can handle rebar. They have a full carbide head and last forever.
KyleVH is offline
