Trade: Remodeling - Carpentry
Best Way To Fasten Plywood Forms To Concrete Block?
For the past 3 years I've been doing 90% finish carpentry. I recently was asked to bid a forming job. I'm from florida where the shell is built in concrete block and then a solid concrete tie-beam is poured on top of the walls.
In the past I've worked with contractors who used case hardened coil nails to shoot the plywood on. And one contractor I worked for tapcnned all the forms on. Shooting the nails seemed to be a quicker way to go, but taking the forms off with the tapcons was nice and clean. I just figured I'd ask to see if anyone had any thoughts on this matter. Also does anyone know what brand coil nailer shoots the hardened nails? I appreciate any info... THANKS |
#2 | |
Professional Instigator
Re: Best Way To Fasten Plywood Forms To Concrete Block?Quote:
Mam, around here we use Cut nails and a hammer Last edited by rbsremodeling; 02-07-2009 at 07:49 PM. |
I would use tapcon even though ramsets are faster just for the ease of removing them, but I don't pour bond beams day in and day out so maybe you don't want to listen to me
#4 | |
General Contractor
Location: St. Petersburg, FL Minds of moderate caliber ordinarily condemn everything which is beyond their range.
Good Lord. A "T" nailer is the absolute ONLY way to go. It takes about 6 seconds to nail on a 2' x 8' 3/4" plywood form side for a lintel run. Put all the sides on the house in about 45 minutes, then you go up top and slap lintel clamps on the whole mess. It's a three hour-two man job, complete, for a 2,500sf house. (OK, maybe a little longer... and three men make it a lot easier...
)Almost all of the 7/8" (or 1" or 1-1/8" if you can't find the 7/8") "T" nails pull right off with the plywood, and the ones that don't, a kid can go around and pull out quickly with a crowbar in about 30 minutes. Don't even think of using anything but a "T" nailer. And you can rent the lintel clamps almost anywhere. But I have to ask, why the heck you aren't using lintel blocks instead? Let the masons do all the work. Here's a picture file with the idea....
"True eloquence consists in saying all that is necessary, and only that which is." François Duc de La Rochefoucauld Bill Everett - St. Petersburg, FL Last edited by Willie T; 02-22-2009 at 07:43 PM. |
IMHO - I'd leave the forming to form carpenters. You are attemtping to take too big of a leap out of your finished carpentry realm.
- Build Well - |
| The Following User Says Thank You to AtlanticWBConst For This Useful Post: | SWAY79 (02-18-2009) |
thanks....especially wiilie t
Trade: Gereral Contractor
4 penny cut nail
David
Trade: Licensed General Contractor
I suggest an ET&F Fastening Systems Model 210 t-nailer. It shoots heat treated t nails from 1" to 2-1/2".
#10 | |
RAPID DOMINANCE.....
Trade: Framing,Roofing,Sheetrock,Concrete,Decks,Screen porches & Flooring
GOOD LUCK
THE ONLY EASY DAY,WAS YESTERDAY.....
| The Following User Says Thank You to SWAY79 For This Useful Post: | sk071077 (02-25-2009) |
Trade: -
Hello
I am not used it ! I will use than say anything ! ok !
Pompass Ass
On clean outs I have had tapcons fail, never had a failure when I used a T Nailer.
#13 | |
Commercial Contractor
Tap Cons in my opinion.
Pilot hole keeps it secure, and creates ease of removal. Just don't strip em' out.
You may be right, I've never heard of a "T" nailer. I may know it by a different name. How does it work? What does it look like?
General Contractor
Type - T Nailer - into your Google window. Click on <images>.
"True eloquence consists in saying all that is necessary, and only that which is." François Duc de La Rochefoucauld Bill Everett - St. Petersburg, FL |
#16 | |
Pompass Ass
Trade: yes
I hope to run a wall parallel to the joists, but not directly underneath a joist, screw a 2 × 4 bridge every 2' to 3' to the joists. Screw the top plate to the bridges.
If you have no pipes at the ceiling, screw the bridge between the joists rather than under them. We opted to build the wall directly below a joist, so we didn't bother with bridges. To allow clearance for pipes and conduit, we screwed blocks of 2 × 4 to the joist, and then attached the top plate to the blocks.
Builders Streatham |
| concrete forms selection | dakota co | Concrete & Paving | 15 | 11-26-2010 10:42 AM |
| Tile on Concrete block wall | Milhaus | Ceramic & Stone Tile | 10 | 01-18-2009 07:07 AM |
| Block up to grade, or pour concrete to grade?? | ruskent | Masonry | 8 | 11-30-2008 11:31 PM |
| How to cap off 8" concrete block wall | Michaeljp86 | General Discussion | 18 | 09-20-2008 08:18 AM |
| Footing Forms for Residential use Clamps/brace for plywood forms | plazaman | Excavation & Site Work | 5 | 08-21-2008 10:21 PM |
