Chief Toilet Mover
Trade: Bathroom Remodeling
Best Way To Attach Hardi Board To Cement Block Wall.
I need to attach some 1/2 inch hardi board to a cement block wall of a bath tub in order to tile it. There are no furring strips and there is no room for any due to matching existing planes.
My thoughts were construction adhesive and some 1 3/4 tapcons. |
Re: Best Way To Attach Hardi Board To Cement Block Wall.
Sounds like a plan to me. I'd spot the TapCons with some spray primer to help against future rust problems. A 1/2 in. hole in a piece of cardboard will work as a shield.
Chief Toilet Mover
You probably deal with a ton of issues like this down in Florida... lots of block to deal with right?
Since they restricted Dade County pine many years ago, block has been the most popular choice with cast concrete being second. With water, termites and hurricanes being popular here, frame homes are not.
Bah Humbug!
I have never read a spec for attaching hardi to a brick wall but have read plenty for attaching vinyl to brick.
I'd use tapcons to install some battons, your going to want the tapcons to be flush with the surface of the battons, so you may have to predrill and counter sink all the holes on your battons. You can then install your vinyl siding to the battons. The problem with this installation is hardi is very heavy and a 1" batton may not have the grip you need and the siding may slip off after a few years. Then again you are talking about sheets (4x8) and I am talking about siding panels. Either way I think same principal. |
Trade: builder remodelor
Why not bed backer board in thin set with a few phillips head tapcons at corners to hold until set. This is similar to method of laying backer on floors.
#7 | |
Trade: carpentry/ self employed master craftsman
Re: Best Way To Attach Hardi Board To Cement Block Wall.Quote:
"what ever it takes" |
What bergenbldr said.
http://www.tr-built.com |
I see at the Fastenal store that they have stainless steel Tapcons. That might be of some interest to you. I'd bet they're probably a buck a piece.
Cabinetmaker
Md :] Just had to buy a box of 50 3/8 SS at Fastenall, With a big discount
92.00!!!!!!!! OwJackM |
Cabinetmaker
MD oppppppppss missed tapcons, I bought SS tapered anchors still OW
Trade: Ca Contractor
fir out the wall using p.t. lumer every 16 inches with tap cons the nail the siding to fir out using galv. nails
Home Improvement Guy
Trade: Renovations contractor
Hey Mike, it's been over 2 years, how did you make out?
Don't worry, the baseboard will hide it! |
| Does fireplace opening in block wall opening need support? | Square-One | Masonry | 6 | 11-22-2008 02:31 AM |
| Concrete Block Wall | skpjose | Construction | 26 | 10-20-2008 04:38 AM |
| Transitioning drywall with cement board | Lone Wrencher | Drywall | 19 | 03-02-2008 07:05 AM |
| Does fireplace opening in block wall opening need support? | Square-One | Construction | 1 | 02-28-2006 01:59 AM |
