Best Sealant For Silicone Modified Polyester Coated Metal Seams?
Old 07-08-2010, 09:27 AM   #1
astamp78's Avatar
Trade: Metal Buildings
Good morning. This is my first post here, looks like you guys have good information. I tried searching but haven't found this topic so far.
I normally use a 100% silicone sealant on metal buildings (silicone modified polyester paint finish). Recently, the metal panel supplier stated that silicone caulking will react with the SMP paint finish and loose its bond over time.
Is this true?
If so, what is recommended for a good, high quality sealant for metal buildings? I was thinking maybe a DAP Dynaflex 230?
Thanks for any help.
Drew
astamp78 is offline
Old 07-08-2010, 10:13 AM   #2
iHandy's Avatar
Trade: (reformed) Small Projects Contractor
Rewards Points: 75
Re: Best Sealant For Silicone Modified Polyester Coated Metal Seams?
Ask the technical support folks from the manufacturer. In my experience this is the best way to go.
iHandy is offline
Old 07-08-2010, 08:42 PM   #3
Tom Struble's Avatar
Trade: siding
Rewards Points: 4
what exactly are you caulking?from what ive gathered over the years silicone is probably not the best sealant for metal roofing,but i guess that all depends on what your sealing
Tom Struble is offline
Old 07-08-2010, 10:01 PM   #4
gallerytungsten's Avatar
Trade: Design
Rewards Points: 250
The Dynaflex 230 is pretty good. However, it does shrink a lot, and it will turn blue in contact with copper. Takes a while to cure.
gallerytungsten is offline
Old 07-08-2010, 10:30 PM   #5
Ray C's Avatar
Rewards Points: 77
I had a pole building that I built years ago and used nails to fasten metal (before screws were being used) and it was a chocalate brown roof and the metal expanded and contracted so much the nail holes got bigger and it started leaking. I got some NP1 and it sure held good--in fact a wind sheer took the building down and that caulk was stuck tight to nails. I cant remember who makes NP1 but I think I got it at ABC Supply. I have had real good luck with Geocel also--it is a tri polymer that expands and contracts real well. One thing -- NP1 guns hard when it is cold, more so than silicone.
Ray C is offline
Corrugated metal fence stanfordconst Decks & Fencing 2 05-31-2010 01:38 PM
Metal roof question Burby Roofing 11 01-22-2009 01:16 PM
stone coated metal roof tile Tom Struble Roofing 4 01-12-2009 03:04 AM
Metal Framing Help gambinos1983 Framing 7 04-06-2008 08:01 PM
