Best Moisture Barrier Behind Hardie?
Old 06-26-2008, 11:36 AM   #1
dgp's Avatar
Trade: General Construction
What do you use under HardiPlank? I'm from the old school and have always favored roofing felt but the Hardie rep says you can get bleedthrough. Are you a believer in the newer engineered materials like Tyvek? Some of the new stuff just seems so thin.
dgp is offline
Crawl Space Ventilation Ed the Roofer Roofing 2 11-27-2008 11:15 AM
Tenwolde's 5 Myths Of Moisture Ed the Roofer Roofing 3 02-10-2008 03:37 PM
Radiant Barrier Fact Sheet Ed the Roofer Roofing 0 02-09-2008 08:57 PM
Flooring over concrete? Moisture barrier? Kevin75 Flooring 29 12-15-2007 08:23 PM
Moisture Barrier BKA Concrete & Paving 3 05-16-2007 04:53 PM
