Best Method Of Installing Ceiling In Garage
This is my personal garage/workshop and I'm ready to install a ceiling in order to effectively heat it to aid working in the winter
thanks |
Thom
Re: Best Method Of Installing Ceiling In Garage
I don't understand why you would strip a 24" oc ceiling with 24" oc strips. We hang 1/2" sheetrock on 24" centers all the time. The reason garages have typically been stripped is because manufacturers required 5/8 type X to be fastened to 16" oc framing.
sorry about the mix-up, I wasn't paying attention and put 1/2" when I meant to type 5/8". Is the norm 5/8" for a 'sagless' ceiling years down the road? There's no concern for fire protection, so the 5/8" isn't needed for that reason. Is it acceptable to put 1/2" up?
Regarding the strips, even though the original thread said 1/2", I was still thinking the strips would help in maintaining the rigidity fo the ceiling as I'm sure there is movement because of the windy conditions we have in my area and the pole building construction. |
Chevy, IRC Building codes say 5/8" type x only for areas seperating habitable space above--like bedrooms. The 1/2" is cheaper of course and if your going to do furring strips why not run them perpendicular @16 o/c. That plan sounds the best.
Thom
I would skip the strips.
sounds like 1/2" drywall w/o the furring strips is OK-thanks Thom.
Trade: general contractor - SFR
I'm with Tom M on this one. Unless you have sprinklers, use 5/8 x to meet code and chuck the furring strips. It'll easily hold up to 24" oc.
Trade: Residential Remodel
Is there some reason you couldn't just use the 1/2" ceiling board. I think it's great. Made specifically for ceilings and easier to hang than 5/8" and as far as I know it meets code.
Rich |
Thom
1/2" will do fine, forget the strips either way.
1/2" will be fine as long has no habitable space is above.
What's the best method for applying adhesive to the bottom chord of the truss to install sheetrock? I've used the old fashioned method of a caulk gun, but sometimes poor pressure doesn't allow it to stick (and it drops off). When installing 4" vinyl base moulding (typically found in commercial settings w/ vinyl tile) a special tip is made for the end of the (large) caulk gun-but its too wide, around 3" wide. Is anything like this made for horizontal application of adhesive?
| installing a ceiling ladder? | jerry1967 | Framing | 30 | 04-07-2007 09:53 AM |
| High ceiling in garage construction | T bone | Construction | 10 | 02-24-2007 10:57 PM |
| Need a garage ceiling drywalled and finished in NW Chicago suburb | just4fun | Help Wanted or Looking For Work | 0 | 11-03-2006 05:43 PM |
| Garage Ceiling Spans | JimmyZimmier | Construction | 9 | 01-03-2006 06:55 PM |
