Basement Under Garage
Old 10-27-2007, 07:36 PM   #1
HandyMan Solution
TNRocks's Avatar
Send a message via Yahoo to TNRocks
Will be building a new home this summer. Would like to put a basement under the garage. Does anybody have any idea what would be involed. Any help would be appricated. Thanks in advance.
TNRocks is offline
Old 10-27-2007, 07:41 PM   #2
Re: Basement Under Garage
Have done that before, in mortuaries...will you be needing the casket lift and doors?
neolitic is offline
Old 10-27-2007, 07:47 PM   #3
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Have done those plenty of times, there called the Boys room, great for pool tables, wet bar, darts and even a brass pole once. Best way I found to do them was to use CoreSlab, or prestressed hollow core slabs. Needs engineer design, it installs flat on my ICF walls and when you pour the cap you add the necessary slope to the garage floor at that time. This is well worth the money.
Chris
Chris Johnson is offline
Old 10-27-2007, 07:55 PM   #4
Point is, wood or concrete, they need to start talking to an engineer.
Just havin' a bit o' fun first.
neolitic is offline
Old 10-27-2007, 08:08 PM   #5
The Grand Wazoo
KillerToiletSpider's Avatar
I've done a couple houses with rooms under the garage, generally the engineer has called for 12" thick steel reinforced foundation walls on all four sides, and flexicore pre engineered concrete slabs for the garage floor, with the flexicore bolted directly to the foundation.
KillerToiletSpider is offline
Old 10-27-2007, 09:54 PM   #6
One funeral home was pre cast, two were cast in place pan slabs. Those two were three...er "car" arrangements, 3 - 9' doors.
neolitic is offline
Old 10-27-2007, 11:09 PM   #7
mdshunk's Avatar
Lots of homes done that way in my area. They even advertise for the product on the radio. Called "Span Decks" for slang, but that might be one manufacturer's name. Here you go:
http://www.nitterhouse.com/BuildingS...sidential.html
mdshunk is offline
Old 10-28-2007, 12:49 AM   #8
Al Smith
A W Smith's Avatar
Precast reinforced concrete floor sections.
http://www.spancrete.com/sf_garage.html
A W Smith is offline
Old 10-28-2007, 09:41 AM   #9
finehomes's Avatar
Trade: Builder/Developer
I've done a million of these here in utah. The company that I use here that makes the precast slabs to install right on top of your foundation is called Eagle Precast. www.eagleprecast.com They have a lot of tech info on their website about the product. You can also check out this link to see an article I wrote several years ago for JLC about the topic. http://www.jlconline.com/cgi-bin/jlc.../View/0206inst
Sam
finehomes is offline
Old 10-28-2007, 10:28 AM   #10
HandyMan Solution
TNRocks's Avatar
Thanks fellows for the quick reply. Looks like I will be doing a lot of research. Appreciate the web sites you have recommended, will be looking into them. I got the idea from a model I visited a few months ago but no one was available to give me any answers and the building wasn't available. So again thanks for the replys.
TNRocks is offline
Would Concrete stair be good going to basement from garage? TurnkeyConst Masonry 1 04-04-2007 09:47 AM
garage insulation maderuyck HVAC 2 03-18-2007 12:43 PM
Brick Footer and Water Proofing emtaboy Excavation & Site Work 24 07-24-2006 09:48 PM
HELP! Basement floor disaster Profiter Construction 5 07-11-2006 09:01 PM
Flat roof over garage leaking under exterior walk out door IHI Roofing 18 05-30-2006 10:28 PM
