Basement Slab Moisture - Page 4 - Construction - Contractor Talk
Old 11-06-2017, 04:51 AM   #61
Box Builder
Morning Wood's Avatar
Rewards Points: 9,054
Re: Basement Slab Moisture
Originally Posted by overanalyze View Post
4th Gen...do you disagree with my solution?
He just disagrees with everyone.
Morning Wood is offline
The Following User Says Thank You to Morning Wood For This Useful Post:
Fouthgeneration (11-06-2017)
Old 11-06-2017, 02:25 PM   #62
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 6,671
No, if You can achieve a vapour 'proof' bond to the concrete with the epoxy you're should be good and dry....
Please post back in a year or two the results.
On sticky AC days the near ground temp slab might, still collect condensation from the air if its dew point is above the floor temperature.....
Damp vinyl linoleum has to be much less as of a mold factory then carpet in the same conditions.
Fouthgeneration is offline
The Following User Says Thank You to Fouthgeneration For This Useful Post:
overanalyze (11-06-2017)
Old 11-06-2017, 07:13 PM   #63
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,076
I am using EliteCrete's waterborne, 2 part epoxy vapor barrier. I will be applying 2 coats. My flooring guy does epoxy floor coatings and had this equipment and let me rent it.
This is an Edco Floor grinder and Edco 200cfm vac. 99% dust free set up. I am amazed at how quick it grinds the slab. I have on the "fine" shoes. The small round ones. The blue and orange are more aggressive. My flooring guy said the more aggressive ones will tear up a slab in a heartbeat! This will give the epoxy a fresh surface to penetrate and adhere to.
overanalyze is online now
The Following 6 Users Say Thank You to overanalyze For This Useful Post:
Fouthgeneration (11-06-2017), Rio (11-08-2017), SmallTownGuy (11-07-2017), superseal (11-08-2017), tgeb (11-09-2017), Xtrememtnbiker (11-06-2017)
Old 11-08-2017, 01:02 PM   #64
cedarboarder's Avatar
Trade: Workaholic
Rewards Points: 1,648
I wanna use it!
cedarboarder is offline
Old 11-08-2017, 07:50 PM   #65
Always Learning
Originally Posted by cedarboarder View Post
I wanna use it!
Ha! It is pretty uneventful to run. Renting a Husqvarna unit tomorrow for a bunch of thinset removal. Be curious to see how they differ.
Old 11-12-2017, 08:59 PM   #66
DiaperRiot's Avatar
Trade: Painting, Landscaping, & Fence Installation
Rewards Points: 148
Take up the planks, and install some moisture mitigating epoxy. That would block the moisture.
DiaperRiot is offline
Old 11-14-2017, 09:28 PM   #67
Always Learning
Umm..have you read any of the topic?...it is what I am doing.
Here is some update pics. I did the epoxy in 2 sections. 2 coats aren't required but recommended. I am not taking any chances so 2 coats it is. Here you can see it all ground, one section 2 coated, and the first coat on the 2nd section.
Xtrememtnbiker (11-15-2017)
Placing Basement Floor Slab in 1 Placement black95gt Concrete & Paving 28 10-04-2014 08:08 AM
Installing solid hardwood on slab Eaglei Flooring 10 05-25-2013 12:42 PM
Effects of moisture content J.C. Finish Carpentry 10 03-06-2013 05:50 PM
2x4 Basement Stud Walls On a Three Story Home WITH NO FOOTER Baltimore Carpentry 13 08-16-2012 07:02 PM
granite slab handling archibaldtuttle Kitchens & Baths 3 10-12-2009 07:25 PM
