Baseboard Height?
Old 12-29-2006, 04:16 PM   #1
BobbyD's Avatar
Baseboard Height?
Need to install some baseboards in the basement, wondering what the correct height should be? The floor is concrete, no sub floor and will be laying carpet with an underpad. I guessing around 3/4 " off the ground, does this sound right?
Thanks
BobbyD is offline
Old 12-29-2006, 04:44 PM   #2
ContractorTalk Flunkie
dayspring's Avatar
Re: Baseboard Height?
We generally hold ours 1/4" off the floor for carpet
T.C.
"Never met a man yet that I couldn't learn something from"
Met a few you couldn't teach though
http://remodelingncarolina.com
dayspring is offline
Old 12-29-2006, 05:54 PM   #3
Mod / ArchiBuilder
Cole's Avatar
Trade: Design/Build Pergolas & Pavilions
Rewards Points: 1,486
Carpenter's pencil on its side.
Cole is offline
Old 12-29-2006, 06:07 PM   #4
K2's Avatar
Trade: Colorado master electrician, EC, B-1 GC
Rewards Points: 2,000
A scrap piece of whatever base i was using, (laying flat), worked great for me. Had plenty to choose from.
Where there was vinyl, tile, etc. I'd hold off until it was down.
K2 is offline
Old 12-29-2006, 07:57 PM   #5
karma_carpentry's Avatar
Trade: carpenter
Rewards Points: 250
I just did exactly that. I used two pieces of the actual carpet and made it snug but not impossible to tuck the carpet under. It turned out to be about 3/8", sometimes a little more due to uneven slab. But there's no underpad. Can you get the spec from the carpet installer? They should know.
I used concrete screws about every 2' - how are you fastening? Are you caulking to concrete or leaving it uncaulked? I decided to leave it uncaulked to not stain the concrete.
Build on a good foundation.
karma_carpentry is offline
Old 12-29-2006, 08:00 PM   #6
Teetorbilt's Avatar
1/2" here due to water. Tack + carpet few notice. Also allows for wire space,
Albert Einstein
Teetorbilt is offline
Old 12-29-2006, 11:28 PM   #7
Thom
thom's Avatar
Rewards Points: 4,748
Carpenter pencil laid flat, lift it just a bit so it's not held in tight.
The idea is the carpet goes over the tack strip and under the base. No pad under the carpet on the wall side of the base so the carpet should be squashed some to make it look right. You don't want to see the bottom edge of the base, it should be into the carpet pile.
thom is offline
Old 12-30-2006, 10:07 AM   #8
BobbyD's Avatar
I went ahead and used a piece of 1/2 drywall as my spacer. Everything looks great, just need to pick out some carpet
Thanks
BobbyD is offline
Old 01-04-2007, 07:41 PM   #9
Kane66
Kane66's Avatar
little late on the reply. what i do for base instalation is cut some (approx) 4"x3" blocks of 7/16" (or 1/2") osb/ply and use them as spacers. this keeps the base at the same off floor heighth.
Kane66 is offline
Old 01-04-2007, 10:35 PM   #10
Thom
thom's Avatar
1/2" is pretty high. Use deep pile carpet so you don't see the bottom edge of the base above the carpet. It really needs to be pushed down onto the carpet pile to look correct.
thom is offline
Baseboard trim before or after carpet mtheisen0814 General Discussion 22 04-03-2012 11:07 PM
Recessed baseboard Maplehead Finish Carpentry 12 03-04-2007 12:13 PM
California Building Codes for Chimney Height vawn Construction 5 05-22-2006 07:49 AM
Baseboard before floor? rhythm-method Flooring 12 04-14-2006 03:55 PM
Baseboard Electric..conversion w/ gas sprinklerguy HVAC 5 12-31-2005 11:38 PM
