Asphalt Based Spray On Exterior Wall
Old 04-27-2010, 09:05 AM   #1
gloryspider's Avatar
Trade: Architectural Services
Hi Everybody,
I have a question regarding finishing exterior concrete blocks in a building, north in Huntsville Ontario:
Is using an asphalt based spray on air barrier considered harmful or not desired for building users ?? Will building users smell this asphaltic material when using the building ?
Thanks in advance.
gloryspider is offline
Old 04-27-2010, 09:31 AM   #2
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Re: Asphalt Based Spray On Exterior Wall
Please don't double post.
Give it some time. During the day, a lot of guys are out working (unlike me right now). Wait until this evening when the board starts to heat up. You should get an answer soon.
Angus
angus242 is offline
Old 05-03-2010, 08:23 PM   #3
JimCarroll's Avatar
Trade: CSI Division 4 & 7
No it does not smell like asphalt. Check out Hyrdrocide 700b by BASF. It is a very common asphalt based vapor barrier that is used on block when covered with a brick veneer.
www.TheBrickCleaner.com
JimCarroll is offline
Spray foam under a slab for insulation -- Mike Finley Construction 22 01-10-2010 02:39 PM
Refinishing - 3 coats oil VS. 4 coats water based poly patrcarl Flooring 3 07-24-2009 10:56 AM
Asphalt driveway rayh78 General Discussion 1 05-22-2009 07:01 AM
Painting Oil based over Latex Mark-It Done Painting & Finish Work 4 03-15-2009 01:45 AM
Does Behr Ext. Satin spray easily? renet Painting & Finish Work 2 11-17-2008 10:31 AM
