Angled Decking Calculating
Old 05-16-2018, 06:12 AM   #1
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 3,024
When planning for a deck with boards run on an angle, how do you determine the length of boards to order from the LY? The longest one is easy especially if you go corner to corner but after that do you just order a bunch of sizes?
Which leads to the next question: Do you set boards corner to corner or on a perfect 45?
Big Johnson is online now
Old 05-16-2018, 06:58 AM   #2
90%-er
onmywayup's Avatar
Rewards Points: 1,446
Re: Angled Decking Calculating
I calculate the square footage of the deck, then order that plus ten percent in the longest boards they have.
As I install, I start with the longest run right down the middle, then start working my way out both ways using the longest boards I have left on the stack as we go. Obviously, seams fall where they need to across joists.
onmywayup is offline
The Following 2 Users Say Thank You to onmywayup For This Useful Post:
Big Johnson (05-16-2018), ScipioAfricanus (05-16-2018)
Old 05-16-2018, 04:49 PM   #3
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 90
Dittos with above mostly... though I try to make sure the deck width will allow for whatever the max length is (so as I recall a 16' can go for a 12' wide deck) they want larger well there cost just jumped exponentially
As for angle versus straight - I prefer angled for numerous reasons but it is whatever the customer wants
SLSTech is offline
The Following User Says Thank You to SLSTech For This Useful Post:
Old 05-16-2018, 06:00 PM   #4
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 3,554
If your using composite boards close up the joist spacing if you angle the boards.
The last one I done the angle was not quite 45 degree's so I could one board with no joints.
sunkist is offline
The Following 2 Users Say Thank You to sunkist For This Useful Post:
asevereid (05-16-2018), Big Johnson (05-16-2018)
Old 05-16-2018, 06:49 PM   #5
Doing 12 OC.
Old 05-16-2018, 07:19 PM   #6
sunkist's Avatar
Still "Shakin" the tree boss
sunkist is offline
Old 05-16-2018, 08:41 PM   #7
General Contractor
greg24k's Avatar
Rewards Points: 7,304
Use decking calculator.
greg24k is offline
Old 05-16-2018, 08:54 PM   #8
GC/carpenter
Californiadecks's Avatar
Rewards Points: 7,064
And you actually use less fasteners with 45 degree boards and 12 inch centers. Vs. Perpendicular at 16 centers.
Mike.
_______________
Californiadecks is offline
The Following User Says Thank You to Californiadecks For This Useful Post:
hid fast on fiboron decking bigcats. Decks & Fencing 7 05-17-2013 07:45 PM
Sealing all sides of hardwood decking DeckPros Decks & Fencing 56 02-16-2013 12:27 PM
calculating crown spring angle Mrmac204 Finish Carpentry 12 12-26-2012 07:08 AM
Bostich Cordless Angled Finish Nailer ? MF Custom Tools & Equipment 19 09-14-2012 10:08 PM
