Addition Around Brick Chimney
Old 05-30-2004, 12:26 AM   #1
Sunny Southern California
Adenmoor's Avatar
Hello all,
I've been working on an addition to my house.
We are keeping an existing fireplace with a brick chimney. I have already framed around the chimney but still need to have the existing chimney extened about 5 feet.
The chimney used to be outside the house but will now be enclosed. Is there anything special I need to do with the chimney itself?
I've heard that I need to demo down to about two feet of rebar before adding back upward. Is this true?
Is it possible to frame a new chimney made of wood built ontop of the existing chimney?
I live in Los Angeles County.
Thanks!
Adenmoor is offline
Old 06-11-2004, 12:43 AM   #2
Adenmoor's Avatar
Re: Addition Around Brick Chimney
I have found out that I have a clay flue.
Does any one know wher I can get a clay flue extension or adaptor so that I can extend using a galvanized flue?
I've called Home Depot, Ganahl Lumber, Lowes and All American; neither knows or has what I need.
Thanks!
Adenmoor is offline
Old 09-17-2004, 01:31 AM   #3
two kids's Avatar
Originally Posted by Adenmoor
Hello all,
Thanks!
Will you be burning wood in this fireplace....the only way you can build a wood chimney over a masonry one is if you are going to all gas logs.....but I would still check your local codes ...this is a fairly big deal since if you do it wrong it will heat up and burn down your house....Here in TN they will not even let us use block to fill the chimney solid anymore,,due to the chimney getting so hot it turns the block into dust....we have to use brick now.
two kids is offline
Thin Brick, VS Regular Brick Project53 Construction 25 03-11-2010 03:13 PM
Questions About a No Good Chimney Bruce Masonry 11 01-02-2007 12:46 AM
Brick Veneer Chimney w/ Factory Insert rhomfeld Carpentry 6 09-15-2006 09:23 PM
Direct vent fireplace into brick wood burning chimney? rach0990 Masonry 3 05-25-2006 07:20 AM
