Adding 2nd Story To Block House
I'm looking at a job where the house is an ornamental block single story where a second story is desired. One corner of the block has settled 1-2" as evidenced by the stair-stepping cracks and visually viewing the course line. The age is probably 80 years old and there doesn't appear to be a traditional foudation-maybe it was dug down 2' or so and the block laid.
HOw would you go about adding a 2nd story to this house? Is there anyway (reasonable) way to pour a foundation under the block wall to make it sound enough to raise the walls? |
Re: Adding 2nd Story To Block House
Chevy dont know all the factors of block but I have seen pier footings poured under critcal corners and point loads. Then the second story can be bridged accordingly. Ask or mention this notion to an architect.
Good luck |
Trade: Masonry consultant
The description of the crack and apparent amount of settlement does not sound good.
Contact an engineer to find out what is going on. You don't want to put additional load on it. Dick |
HomeXpressons
Trade: General Contractor/ Pro Renovator
A good foundation company can work this out for you. I agree with the notion of a structural engineer first before the second story. If you are contemplating wood walls ten when you remove the existing roof you need to drop in some rebar fill some cell walls with concrete and install a tie beam.This will help strengthen the whole thing.
| Best way to ventilate a hot house? | SuperiorBuilt | General Discussion | 12 | 06-03-2007 01:40 PM |
| Parging Block | lukachuki | Masonry | 9 | 11-21-2006 08:23 PM |
| siding on a block house? | ricks_plumbing | Windows, Siding and Doors | 3 | 03-16-2006 02:57 PM |
| Adding a 2nd story on a flat roof | 20Two | Remodeling | 3 | 05-17-2005 12:55 AM |
| Block Work/Southern Fla. | Glasshousebltr | Construction | 0 | 03-16-2004 04:21 PM |
