2nd Floor Concrete Slab
Old 07-08-2012, 12:58 PM   #1
BananaBeachBum's Avatar
Trade: General Contractor/Builder
Lightbulb
I am constructing a 10 unit 2 story condo building with concrete block and 10in. square poured concrete beams and columns. I have 10 in. square columns and concrete block wall supporting 10in beams @ 12ft on centers front to back. I have 3" x 6" X 16ft treated wood beams @ 3ft on center between the columns front to back for a clear span of approx 15 ft. Above the 3 x 6 beams is nailed in place tongue and grove 3/4" planking which will be a stained ceiling below and support for the 4 " concrete floor above. Whew!! My question is what should the rebar size and spacing be??
BananaBeachBum is offline
Old 07-08-2012, 01:10 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 1,158
Re: 2nd Floor Concrete Slab
You're kidding, right...?
Multi story, concrete?
No notes on the plans...
Sounds to me like you are in a foreign country...
that requires minimal or no plans ^ no such thing as engineering.
Saw a lot of this in Mexico & Baja...
griz is offline
The Following 2 Users Say Thank You to griz For This Useful Post:
ScipioAfricanus (07-08-2012), tgeb (07-12-2012)
Old 07-08-2012, 01:23 PM   #3
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Rewards Points: 4,254
Good luck with that one
Chris
Chris Johnson is offline
The Following User Says Thank You to Chris Johnson For This Useful Post:
tgeb (07-12-2012)
Old 07-08-2012, 02:54 PM   #4
Rockmonster's Avatar
Trade: Masonry
Rewards Points: 5,494
#9 both ways, 2" o.c.
Rockmonster is offline
The Following 2 Users Say Thank You to Rockmonster For This Useful Post:
MSLiechty (07-08-2012), slowsol (07-08-2012)
Old 07-08-2012, 03:47 PM   #5
Eater of sins.
ScipioAfricanus's Avatar
Trade: Designer/Drafter Extraordinaire
Rewards Points: 1,082
That's damn funny there.
Andy.
ScipioAfricanus is offline
Old 07-08-2012, 04:59 PM   #6
rshad28's Avatar
Rewards Points: 12
KMR
– Request for Information:
Ques. #1
Is the T&G Planking on-top or below, it was unclear.
Above or below the 3”x6” Wood Beam?
Ques. #2
Is it regulation in your area to have 4” Concrete topping? With the ” T&G Planking? If there is a subfloor, it should be okay with 1-1/2” or 1” topping. What location are you designing for?
Ques. #3
Can you elaborate in more detail as to:
the Foundation system, then,
the Level 1 floor system, then,
the Level 1 wall system (supporting Level 2 above), then,
the Level 2 floor system, then,
the Level 2 wall system (supporting Roof over-head), then,
the Roof assembly (flat-roof? Sloped roof?)
These questions will help, us, determine loadings on your floor.
Rashaad (owner)
Know More Research
204-227-0394
rshad28 is offline
Old 07-09-2012, 12:47 PM   #7
Kabe's Avatar
Trade: General
Not sure which municipality is applicable - but I suspect this would require a PE seal for a 2-story reinforced concrete structure. If so, the plans would be deficient if these details weren't called out. I wouldn't take the responsibility that doesn't - and can't (unless you're a PE) reside with you.
How is the slab integrated with the structure? No shear studs or similar? Again - consult the licensed engineer of record - but a steel decking could be used over the 3/4" T&G. The Steel Deck Institute has several publications guiding the design of steel decking concrete floor systems.
Kabe is offline
Old 07-12-2012, 12:45 PM   #8
Clark Bilston's Avatar
Trade: Renovations
Rewards Points: 150
Id totally just wing something like that. You might wind up getting bad advice off the internet.
Clark Bilston is offline
Old 07-13-2012, 03:49 PM   #9
chew's Avatar
Trade: All
Rewards Points: 117
only if if you use #7 stone in the mix (ACI 318-3.3.2)
chew is offline
Old 07-14-2012, 11:33 AM   #10
mrcharles's Avatar
Trade: GC, Remodeling
Rewards Points: 1,652
Just off the top of my head...# 7 is three inch right? Did I win?
mrcharles is offline
Old 07-15-2012, 07:32 PM   #11
chew's Avatar
Trade: All
Rewards Points: 117
You lose #7 stone is 1/4" -1/2" in size. When designing a mix you need to take in account the rebar spacing & the distance from the bottom of the form to the bottom of rebar. The stone should not be bigger than 3/4 of the spacing & not bigger than 1/5 of the distance from the bottom of the form to the bottom of rebar, but exceptions can be made.
chew is offline
Old 07-16-2012, 01:18 PM   #12
mrcharles's Avatar
I lose.... I was thinking CA-1 that is 3"
concrete slab HUDSONVALLEYEXT Construction 4 06-04-2012 12:45 PM
joint between brick pavers and slab phnola Landscaping 3 04-18-2012 08:38 PM
addition slab lower then original peakecg Construction 5 01-18-2012 04:30 PM
Flagstone over slab paulbronson Flooring 2 10-26-2009 07:15 PM
granite slab handling archibaldtuttle Kitchens & Baths 3 10-12-2009 07:25 PM
