20ga Or 25ga Metal Studs
Old 01-10-2011, 03:54 PM   #1
gnxtc2's Avatar
Trade: NJ Licensed Electrician
Rewards Points: 25
Getting ready to stud out my new shop's walls. Going to use metal studs. The walls are 12' high. Planning to install either plywood or OSB on the bottom 4'. The other 8' will probably be metal panel liner.
To attach the panel liner, I have to run 2 strips of 4" wide flat stock to support the center of the panel liner. The top and bottom will have J channel.
I'm not planning on hanging anything on the walls. I don't like the look of things hanging on a wall.
I am gearing towards the 25ga studs because of the extra horizontal support I'm adding. Going to 20ga metal framing is almost double the cost of 25ga.
Opinions?
Billy T.
gnxtc2@aol.com
gnxtc2 is offline
Old 01-10-2011, 04:07 PM   #2
GettingBy's Avatar
Rewards Points: 6,486
Re: 20ga Or 25ga Metal Studs
Opinions?
Billy T.
gnxtc2@aol.com
http://www.awci.org/cd/pdfs/9710_b.pdf
seems like you might get almost twice the strength with 20 vs. 25 but do you get more than twice the benefit with 20 ga.? Do you need that much strength, overall? Is this a load-bearing wall?
GettingBy is offline
Old 01-10-2011, 04:24 PM   #3
gnxtc2's Avatar
Rewards Points: 25
No load bearing wall. Just need walls for insulating purposes and to attach wall covering.
Billy T.
gnxtc2@aol.com
gnxtc2 is offline
Old 01-10-2011, 04:32 PM   #4
Finish Carpenter
TBFGhost's Avatar
Trade: Finish Carpentry, Reno
Rewards Points: 2,760
I would go with 25 gauge and use stiffiners at mid span... The OSB at the bottom will really tighten things up, be aware that if you want the screws that hold the OSB to counter sink, you will have to use a counter sink first. Not enough meat on a 25 awg stud to pull a screw through OSB.
Where abouts in NNJ are you?
TBFGhost is offline
The Following User Says Thank You to TBFGhost For This Useful Post:
WarriorWithWood (01-13-2011)
Old 01-16-2011, 06:59 PM   #5
General Contractor
Premier_929's Avatar
Trade: Residential and Commercial Renovations
Rewards Points: 75
I would only use 25 ga studs for residential app. In my opinion, any commercial application, including shops, stores, rest. use 20ga.
Premier_929 is offline
Old 03-22-2011, 09:12 PM   #6
Bossman7121's Avatar
Trade: Certified General Contractor
Can you get 22ga readily? We have that option here, and the cost is roughly 22% more as opposed to double. HUGE difference from 25ga Home Depot type 25's. We never go below the 22's anyway. 20't at double the cost seems steep too. Shop it a bit.
Bossman7121 is offline
Old 03-24-2011, 06:06 PM   #7
Bweikel's Avatar
Trade: Carpenter/gc
Rewards Points: 250
25 is fine if your just insulating and hanging they use 25 in cheap track homes and even in cheap hotels.
Bweikel is offline
Old 03-24-2011, 09:09 PM   #8
ricksault's Avatar
Trade: general contractor, concrete contractor
25G fine for furring out and hanging 1/2" drywall when left at 8'.. Most steel stud applications here on West Coast are for commercial projects where we run studs past ceiling tiles, thus at minimum 10'. hanging 10' of 5/8'' drywall on 25G studs could get sketchy. Another use for 25G would be for creating decorative soffits with 1/2" rock, just space them at 16" OC and use ceiling board
ricksault is offline
Old 03-24-2011, 09:22 PM   #9
Anti-wingnut's Avatar
Rewards Points: 3,310
Not true in the Puget Willamette seismic zone or the western US
Actually no problem
Anti-wingnut is offline
Old 03-25-2011, 04:32 PM   #10
Finish Carpenter
TBFGhost's Avatar
Yeah, I agree with Anti. I have put up 10 foot walls and hung 5/8 rock on 25 awg studs no problem. IIFC I think I have done all the way up to 14' with mid span stifferners.
TBFGhost is offline
Old 03-25-2011, 07:22 PM   #11
What is panel liner
Old 03-29-2011, 08:50 PM   #12
gnxtc2's Avatar
Rewards Points: 25
Originally Posted by Anti-wingnut View Post
What is panel liner
The white corrugated stuff on the ceiling and wall.
Billy T.
gnxtc2@aol.com
gnxtc2 is offline
Old 03-29-2011, 10:00 PM   #13
SHI's Avatar
Trade: UNION CARPENTER
Rewards Points: 75
I would go with 20G studs.25G are to light for me
SHI is offline
metal studs and 7 1/4 oak flooring mikeybobo Contractor Swap 1 10-16-2010 07:20 AM
Help attaching cabinets to metal studs. BirmanBuilders Finish Carpentry 31 03-15-2010 09:32 AM
metal studs atmtle Construction 3 12-17-2009 12:15 PM
Attaching wood studs to metal studs AlSmith Framing 13 05-16-2009 10:58 PM
metal studs huckaberry3 General Discussion 7 03-26-2009 12:38 AM
