2 Year Old House
Old 08-17-2006, 11:08 PM   #1
Remodeler
lxdollarsxl's Avatar
Trade: Remodeler/Painter
Send a message via Yahoo to lxdollarsxl
2 Year Old House
This is a small job i recently was asked to do there are 2 sets of french doors that are in this condition after such a short time.
Damned if im gonna do it more than once.
lxdollarsxl is offline
Old 08-17-2006, 11:17 PM   #2
Teetorbilt's Avatar
Re: 2 Year Old House
No builders ins.? Bracket fungus don't grow overnight. Something's terribly wrong here.
Albert Einstein
Teetorbilt is offline
Old 08-17-2006, 11:19 PM   #3
Tom R's Avatar
Don't touch that job, - - you'll be gettin' sued along with the rest of 'em!!
Tom R is offline
Old 08-17-2006, 11:24 PM   #4
Remodeler
Dont worry tom - not even with a very long barge pole
Old 08-18-2006, 12:16 AM   #5
Donedat's Avatar
Trade: Hardwood Flooring
Send a message via MSN to Donedat
Is that the door manufacturer's bad storage product...or what??
I admit...I don't know everything...but don't tell my kids I told you.
Donedat is offline
Old 08-18-2006, 12:17 AM   #6
mdshunk's Avatar
Oh my. It looks like that brickmold was never painted. Looks like it still has the factory primer on it.
Oh my, again. Is that your car key you stuck in the jamb just to show how rotten the wood is? Jeeze.
mdshunk is offline
Old 08-18-2006, 08:29 AM   #7
Moderator
Double-A's Avatar
Bracket fungus on the steering column. Eep!
We just repaired some french doors that were suffering from rot. Seems the sweeps didn't do a good job except for directing water (getting under the door from splash on the deck) sideways to the jambs.
The jambs just soaked up the water like a sponge. When we use prehung steels like this (we try hard not to) we prime every last exposed piece of wood before they go into the rough opening with two coats.
New York Times, July 20, 2006
Double-A is offline
Old 08-18-2006, 10:53 AM   #8
Peladu's Avatar
When I install both exterior doors and interior bathroom doors I will hit the bottom of the jambs (the part that sits on the floor) with a heavy coat of poly to seal it up. I feel it has to help avoid water wicking up the door in the future. I have been told that I am waisting my time, but I think it's all of the little things that add up. I was never taught this practice, just decided it made sense. Also, my painter knows to poly/paint the underside of all interior doors, because I do check and he has been sent back. But maybe that is just me.
Peladu is offline
Old 08-19-2006, 05:22 PM   #9
Donedat's Avatar
Good for you Peladu. Extreme climates require extreme measures. If it's not the moisture, then it's the bugs. Doors should last the lifetime of the home. When I inspect a home to receive a new hardwood floor, I always check the doors and windows in rooms we are installing in. I tell the home owners to do improvements in those areas before installing hardwood flooring. It costs them more but in the long-run, it pays off.
Donedat is offline
Old 08-19-2006, 06:01 PM   #10
Home Improvement Guy
ron schenker's Avatar
Trade: Renovations contractor
Seeing those mushrooms makes me hungry
Don't worry, the baseboard will hide it!
ron schenker is offline
Old 08-19-2006, 06:46 PM   #11
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Company policy, we paint all 6 sides of new doors. Always.
ProWallGuy is offline
Old 08-19-2006, 06:46 PM   #12
ProWallGuy's Avatar
Makes me want to hallucinate.
Old 08-19-2006, 08:45 PM   #13
Remodeler
Yes those are my keys, and your correct they hadnt had a lick of paint apart from the primer at the factory - i told HO to contact the builder as they should do the fix for free. It was their fault it was not painted and sealed. The mind boggles
House moving Toolwh@#e Excavation & Site Work 10 10-21-2007 11:23 PM
Unfinished house eppdso Carpentry 3 08-04-2007 03:16 PM
New Ductwork for Beach House HouseMedic HVAC 4 07-30-2007 05:18 PM
Knocked out power at customers house AHS Electrical 3 11-10-2006 07:43 PM
The foundation for my house hishighness Construction 1 08-30-2006 08:13 AM
