11 7/8" I-joists
Old 03-10-2008, 05:40 PM   #1
Youngster
Cache's Avatar
Trade: Builder / Consultant / Designer
11 7/8" I-joists
Would anyone have any info or links to info regarding cantilevering standard 11 7/8" OSB webbed I-joists. I'm wondering how far I would be able to cantilever a dining nook. Up to 4' would be great and fit in the plans very well. Just wondering if those 12" i-joists can handle a 4' cantilever for the bay window.
Cache is offline
Old 03-10-2008, 05:46 PM   #2
oldfrt's Avatar
Re: 11 7/8" I-joists
Go to this link for specs
PAGES 11-13
http://www.ilevel.com/literature/COM-2000.pdf
oldfrt is offline
Old 03-10-2008, 06:11 PM   #3
Joe Carola's Avatar
Trade: Framing Contractor
As far a I know, no I-joists can be cantilevered 4", especially 11-7/8". Either way. you have to follow a installation instructions for whatever brand I-joists you will be using.
If you want to cantilever 4', you can using steel or lvl's with flitch plates in between designed by an Architect or Engineer. Or you can cantilever joists into a double box that acts as a header and then support that with structural brackets back to the house
Joe Carola
Joe Carola is offline
Old 03-11-2008, 12:04 PM   #4
Youngster
Cache's Avatar
Thanks OldFrt,
So according to these specs, a 2X10 LSL cantilever from Timberstrand shouldn't have any problem making a 4' extension off my dining room.
Cache is offline
Old 03-11-2008, 08:02 PM   #5
oldfrt's Avatar
Thanks OldFrt,
I used the 2"x12" for a 4' cantilever in addition to 2 2'x12' lam beams to box around a chimney.My application was for 1 1/2 stories with a lot of glass engineered my the lumber yard,and it hasn't moved in 7 years.
I just crawled under it this past fall to finally insulate it ,so I threw a level on it to check.It can be done but get it approved.
I used mine as an afterthought to give this side of the house a little break in the wall and keep the whole chimney inside for thermal mass. The area between the chimney and the outside wall became the firewood bin.
11 7/8" i-joists-ttr.jpg
oldfrt is offline
Old 03-11-2008, 08:32 PM   #6
REDRC's Avatar
FWIW, when I used to frame, as long as 2/3 of the joist was inside that was all that had to happen. So for 4' overhang, you would have to have atleast
8' inside secured. Not sure how much has changed, but this is how we did it 8 years ago.
Thanks.
REDRC is offline
Old 03-11-2008, 08:38 PM   #7
Priced In
JustaFramer's Avatar
Trade: Exiled For Life
JustaFramer is offline
Old 03-11-2008, 08:39 PM   #8
Priced In
Thanks.
That still works for dimensional lumber. Engineered I joists can only be canted max 1'6 or may be 2 feet.
Old 03-11-2008, 08:48 PM   #9
oldfrt's Avatar
I should mention that the outside,weight bearing walls were over a cantilevered 2 2"x12" lam beams running back 20' and the TJI's were just carrying the floor.
oldfrt is offline
Old 03-11-2008, 09:32 PM   #10
RobertCDF's Avatar
Trade: Custom deck builder
I have seen i joists canted 4' before. There was a beam out there as well because the thing was 4'x10 with another story on top and roof too. The beam was trip 11 7/8" ML following the 3:1 rule. The joists also followed the rule. It can be done but it will need to be stamped I am sure.
RobertCDF is offline
Old 03-17-2008, 10:57 AM   #11
Youngster
Cache's Avatar
Thanks guys. I've considered all the suggestions and talked to a couple people. Looks like the i-joists aren't intended to be left open ended. Very good for spanning larger distances than dimensional lumber at a fraction of the overall thickness and weight, but not very stable if not secured well at both ends.
Looks like I'm gonna go with the 2x10 LSL cants. That should be plently for supporting a dining room. My front foyer is gonna be canted about 2' also, but that shouldn't really be an issue. The only issue there is that it will be supporting two stories and a gable.
Thanks again for all the suggestions.
Cache is offline
Sistering Sagging Floor Joists.... AllGoNoShow Construction 22 02-25-2011 04:37 PM
Connecting wood floor joists to concrete block structure in century home. bob_cntrctr Masonry 12 02-26-2008 12:27 PM
Cutting floor joists flush to a wall- preferred tool? Dustball Framing 20 01-29-2008 10:28 PM
Framing Roof Joists for Addition when top Plate is not Level personalt Framing 3 07-20-2007 06:52 AM
Top mounted hangers against fire rated plywood, do studs and joists need to line up? personalt Carpentry 2 08-20-2006 04:24 PM
