Vinyl Siding Cutter
Old 02-19-2007, 06:14 PM   #1
lemoncoke's Avatar
Trade: decks and remodeling
Vinyl Siding Cutter
Does anyone know where I can get plans for making a guillotine vinyl siding cutter or know how to make one if so it would be very appericated. thanks Rick
lemoncoke is offline
Old 03-02-2008, 07:47 PM   #2
Siding Windows Doors
easy sider's Avatar
Trade: Exteriors
Re: Vinyl Siding Cutter
Gillotines are used for cutting metal siding. Vinyl is cut with a saw. You can make your own cutting stand or buy a radial arm saw.
easy sider is offline
Old 03-02-2008, 08:00 PM   #3
Patrick's Avatar
The make them for vinyl. Expensive though, bout $300 + you change out the cutting blade depending on what profile siding you are using. Why someone would actually want one of these is beyond me.
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline
Old 03-07-2008, 01:43 AM   #4
siding savage's Avatar
Trade: Siding
use tin snips they work great
siding savage is offline
Old 04-11-2008, 06:15 PM   #5
Pigs In Pearls!
shazamyman's Avatar
Trade: home improvements
you can build a box for a circular saw on a table...of corse run yer saw backwards, or filp your blade
i worked for a guy that built one hwe put a tape on it and every thing....the only thing was is it wasnt long enough to cut 5 pcs. of siding
shazamyman is offline
Siding: Aluminum vs. Vinyl Grumpy Windows, Siding and Doors 21 03-30-2010 08:02 PM
removing egg from vinyl siding Zeebo Painting & Finish Work 14 03-23-2010 11:19 AM
Vinyl Siding Price joyh23 Windows, Siding and Doors 28 09-04-2009 07:54 PM
Watertight integrity of viynl siding? mci2980 Windows, Siding and Doors 71 11-24-2007 04:15 PM
vinyl siding cutter lemoncoke Windows, Siding and Doors 0 02-19-2007 10:07 PM
