I wouldn't rely on caulk for the long term.
If they aren't interested in eventually replacing the old aluminum siding then here's a couple options.
1)Try and slide an L shaped piece of coil behind old siding and trim as stated in option #2
2)Remove the outside trim,slide aluminum L behind siding with one leg facing out.
Replace wood trim,and cover with coil shaped to include J,less the back bend,and pin nail through L into side of wood trim.
Extend bottom of side L's to divert water from sides to over top of siding by making a slit in lower part of 8" panel.
3)Bend window sides with J,minus back leg,apply as stated above,and address the top trim by getting under the siding so water is diverted over the top of window,and also well past the sides.
Just like a drip cap over the window trim,extending beyond the built in J.
There is no warranty, expressed or implied, as to the accuracy, reliability or completeness of furnished data.Information gathered here may be for the sole purpose of entertainment.
