Woodpecker Probem--Vinyl Siding
Old 10-17-2009, 02:30 PM   #1
davinci's Avatar
Trade: roofing
when tearing off pre existing siding and you're confronted with some holes in the sheathing due to woodpeckers, how do most of you guys address it?
do you need to fill in the holes with anything(if so ,what)?
or can you just tyvek over the holes and then throw up your siding or insulation board?
davinci is offline
Old 10-17-2009, 02:47 PM   #2
mics_54's Avatar
Trade: contractor
Re: Woodpecker Probem--Vinyl Siding
oops misread...sure if the holes arent HUGE. Why not. Cover it up
mics_54 is offline
Old 10-17-2009, 03:03 PM   #3
Jeff
jkfox624's Avatar
Trade: master turd burglar
Woodpeckers wtf? Cant say ive ever seen woodpecker holes in a house. They must have a major insect problem for woodpeckers to be goin to town on the sheathing.
jkfox624 is offline
Old 10-17-2009, 06:58 PM   #4
buddy110's Avatar
Trade: Exteriors as a whole
Send a message via AIM to buddy110
Soon Woodpeckers will morph into Vinylpeckers.
buddy110 is offline
Old 10-17-2009, 07:52 PM   #5
KemoSabe
loneframer's Avatar
Man I have to get used to that edit button being there. Anyway, I have had woodpeckers in my gutters. Apparently they like the bugs in there when they are full of leaves.
loneframer is online now
Old 10-17-2009, 09:45 PM   #6
Lack Of All Trades
Darwin's Avatar
Trade: Professional handyman services
I would repair the hole(s). Sheathing is there for a reason. Any holes in it should be repaired. Won't take much time.
Sure, the client will not realize the holes weren't repaired. But you would. How could you sleep at night knowing you didn't repair those holes like you should have!
Submit a change order and just repair those holes!
Darwin is offline
Old 10-17-2009, 11:45 PM   #7
Anderson's Avatar
Trade: Home improvement contractor
I have repaired several houses with woodpecker holes and I have seen several efforts to thwart the woodpeckers. Mostly electric owls, thing like that. However just the other day I was at a lovely old lady and she had tied tin foil, aluminum foil, to the down pipes on the corners of her house and swears by it. I had never seen this before,
Anderson is offline
Old 10-18-2009, 09:34 AM   #8
Tom Struble's Avatar
Trade: siding
old ladies put tin foil on everything
how big are the holes
Tom Struble is offline
Old 10-18-2009, 03:41 PM   #9
CharlesD's Avatar
Trade: Remodeling/building
If the holes go through the wood siding and sheating into the wall or attic it's probably a rat or squirrel or even a carpenter bumblebee.
I've never seen woodpeckers do anything but poke holes in the cedar or cypress siding. I never seen them bother fir or pine or go into the sheating.
Woodpecker holes would get me several vinyl siding jobs a year. Loved those woodpeckers. If a person has cedar or cypress siding and are in an area where there are lots of woodpeckers they're going to fight a losing battle against them.
I'd never cover cedar or cypress up with new siding--always a tearoff.
Probably 99% of the stuff I tore off would be eight inch battenboard siding. Sawmills rough sawed the stuff for homeowners and builders in our area.
They'd put the stuff up before it was dry but that's another story.
CharlesD is offline
Old 10-18-2009, 06:26 PM   #10
enforcer's Avatar
Trade: windows-siding
never have seen this myself; interesting..what would you guys do to repair/fill any holes in the sheathing?
enforcer is offline
Old 10-19-2009, 10:15 PM   #11
Red Adobe's Avatar
Trade: Siding, Metal Roofs, and Beer Drinking PRO
Since you took the time to post i supose your one of the few whos going to care bout whats right. thats a good thing
use a 3 or 4" holesaw (if that big) cut some plugs the same thickness then a make some pieces of flashing a couple inches biger and screw to slugs to flashing them put a bead around and plug them fill holes.
I treat every home like i might own it someday, I sleep well that way. Its the little easy things that make difference in an honest mans work.
Red Adobe is offline
Old 10-19-2009, 10:40 PM   #12
davinci's Avatar
Trade: roofing
great idea,thats basically what i thought needed to be done.appreciate your response.
davinci is offline
Old 10-20-2009, 08:00 PM   #13
Trade: siding
if the holes are big, cut the ply from stud to stud and patch the sheathing like any carpenter would
Siding: Aluminum vs. Vinyl Grumpy Windows, Siding and Doors 21 03-30-2010 08:02 PM
vinyl siding cutting table platinumLLC Windows, Siding and Doors 16 08-15-2009 11:54 AM
Liquid Vinyl Siding Mitch M Painting & Finish Work 3 04-15-2009 09:19 PM
Painting vinyl siding workpot Painting & Finish Work 18 11-06-2008 07:04 AM
log cabin vinyl siding Home Serve Windows, Siding and Doors 6 04-28-2008 08:16 AM
