Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Specialty Trades > Windows, Siding and Doors
Old 09-06-2009, 12:33 PM   #1
Flatrooferstl
Trade: Roofing
Window sill slope on building
Im waterproofing a building for a customer and have found much interior damage due to the exterior window sills being open at meeting points of brick sill and window itself. how long would caulking lasts and would it be better to apply new slope of concrete mound towards outer building to guide water.
Flatrooferstl is offline   Reply With Quote
Old 09-14-2009, 03:15 PM   #2
Trade: Windows Waterproofing
depends on what you use... Ureatheane sealants will you 2-10 years depending on exposure. Latex will get you 6 months to 2 years, painting it will help in both uretheanes and Latex. A "Good" Nutural cure silicone will last 10-50 years. Dollar for dollar Dow Corning contractors weather proofing sealant will be the best. Performance wise i would say Dow Corning 790... Check on the SWRI web site you will see both products highly rated.
Also, the sills should be sloped away from the building atleast 5 degrees... If someone put sills installed sloping towards a building they should exiled from contruction.
SealantEngineer is offline   Reply With Quote
Old 09-14-2009, 04:42 PM   #3
nEighter's Avatar
Trade: Painting/Framing/Drywall/Tile
The code states elastomeric.. but eurathane will surely be a good alternative. Do it right, don't go cheap and all will be good. Tell them the life expectancy and let them know they will have to check the windows every 3 months or so to make sure the caulking is holding up.
nEighter is online now   Reply With Quote
Old 09-14-2009, 06:08 PM   #4
Carpenter
WNYcarpenter's Avatar
Trade: custom homebuilding/remodeling/restoration
redoing the sill would be best...I wouldn't trust caulk too long. Can you rivot a metal "L" bend to the window the caulk?
Any pics?
WNYcarpenter is offline   Reply With Quote
Jack Stud Sizing under Window Headers? stranchina Construction 15 01-13-2009 11:33 PM
Joasis (and others) how much would this building cost in your area? Mike Finley Construction 8 09-15-2008 02:51 PM
window sill gary4697 Finish Carpentry 1 03-16-2007 07:33 PM
Bay window Tonkadad Construction 11 12-13-2005 07:31 AM
