Trade: roofing
Window Question For You Guys---
having new basement replacement windows put in. frame is kind of old. when replacing the frame,you guys use pine?
Re: Window Question For You Guys---
Vinyl replacement windows works for me....
Cabinetmaker
replacements like Jon said BUT if you have to replace the frames I would use PT now that it is available.
Insert title
Trade: Doors-Windows-Decks
The only problem with PT is working with it if it is really wet. As the wood shrinks it can pull away from your caulking.
To get the best replacement windows, or sun rooms contact the replacement windows experts at FHI Vinyl Window Company. |
Trade: roofing
if parts of the frame are rotted,then i guess pine is what most guys use ?
You can get the replacements where you remove everything that exists...place the replacement in the opening...then you screw in the provided screws that press outward and hold the window in with a foot on the end of the screw...caulk around the inside and outside...and be done with it...
#7 | |
Insert title
Re: Window Question For You Guys---Quote:
Do like Jon said and fill the opening with a window unit you will have more glass area and will not have to deal with rot again. If you feel like framing the window in a little try AZEK.
President
Trade: Installing windows, siding, roofing, doors, patio rooms, gutters and shutters.
We do a lot of basement windows, more than we want sometimes. We always use vinyl windows. If we are changing all the basement windows we try to pull out the old frames and use a window the full size of the opening. Base on R O. If we are not changing all the windows but maybe one or two because they have rot we will rebuild the bucks in P.T. unless we are going to wrap them in coil then we will use pine and make sure they are sealed.
Trade: roofing
you guys get a lower price for removing and installing a basement window opposed to a regular double hung?
President
If we rebuild the buck we get almost the same price as we do for a double hung. Most of the times these are in older homes with dirt basements, crawl spaces or worst under decks and are just a pain to do. I'm in the central part of Maine and we have a lot of homes 100 to 200 years old.
| estimating guide for windows? | Grumpy | Windows, Siding and Doors | 20 | 11-26-2010 08:18 PM |
| question for you stair guys | JPhelps | Finish Carpentry | 5 | 08-29-2007 05:58 PM |
| Question for you drywall guys and prehung doors | carlspackler | Drywall | 4 | 11-30-2006 08:33 AM |
| Window Seat and Bookshelves in Fonr of Baseboard Heating | Richie-C | Finish Carpentry | 10 | 04-04-2006 09:05 PM |
| Window height question | charlesb | Construction | 14 | 01-15-2005 11:02 PM |
