Window Problem
Old 05-22-2006, 12:11 PM   #1
pburchett's Avatar
Trade: General
Window Problem
Building my family a new house. It has a walkout basement. The construction is stick framed, with OSB sheeting, then Tyvek house wrap and brick. During construction the construction process the OSB got wet a few times and it has swelled causing it to bow between the 2x6 basement studs. This in turn has caused the vinyl window frames to bow inward towards the sliding panes and they have become difficult to open and close.
Photos at newhouse.8k.com
The basement has been dryed in for 4 months, but and the OSB is still bowed between studs. I have drilled holes in the OSB to help it get a little air movement. Could I drive some 2x6 boards horizontally between the studs at the top and bottom of the window to help spread the window and release some of the pressure on the window???
Any other suggestions?
pburchett is offline
Old 05-22-2006, 11:51 PM   #2
reveivl's Avatar
Trade: Renovations
Re: Window Problem
Did you leave room for expansion between the sheets when you applied them? This actually might be your problem rather than "The OSB got wet." Do you already have the brick on or can you still get at the OSB?
reveivl is offline
Old 05-24-2006, 10:09 AM   #3
pburchett's Avatar
Trade: General
Re: Window Problem
We did leave some room for expansion between the sheets when applied. The brick is on, and the only side of the OSB I can get to is the backside. The OSB did get wet a few times before the roof was on.
Old 05-26-2006, 01:34 PM   #4
TimNJ's Avatar
Re: Window Problem
How did you install the windows? Are they nailed with nail fins? Are there jamb screws through the jambs?
TimNJ is offline
Old 05-26-2006, 04:47 PM   #5
jack of all, master of 1
snapper21's Avatar
Trade: carpenter/roofer
Re: Window Problem
Is the brick strapped to the osb?
snapper21 is offline
Old 05-30-2006, 12:14 PM   #6
vinylguy's Avatar
Trade: vinyl decking railing fenceing siding windows
Re: Window Problem
i don't get it osb on your basement wall ? why would you stick biuld a basement below ground level? maybe i'm missing something but did i not read this is a foundation?
vinylguy is offline
Replacement Window Question? Max10 Windows, Siding and Doors 34 02-27-2010 06:15 PM
cutting window openings into brick faced house Mr. D Masonry 5 11-14-2006 01:55 PM
Problem: Window replacement/restoration in 1905 house. hipgrrrrl Windows, Siding and Doors 7 10-03-2006 10:29 AM
Pre Cast Window Don H Drywall 7 09-20-2006 11:01 PM
Window Seat and Bookshelves in Fonr of Baseboard Heating Richie-C Finish Carpentry 10 04-04-2006 09:05 PM
