Window Leaks...Hmmm Wonder Why!
Old 10-27-2005, 10:09 PM   #1
pitterpat's Avatar
Trade: HandyWOMAN
The homeowner of this house told me that this window leaked when it rained from the west. This window is on the west side of the house. Here's pictures of the window b/4 taking the trim off and after (don't miss the hole I put in the trim when I first looked at it and was pushing on the wood). Got it figured out why this window leaks????
Window leaks...Hmmm wonder why!-w-window-w-trim-full.jpg   Window leaks...Hmmm wonder why!-w-window-wo-trim-full.jpg   Window leaks...Hmmm wonder why!-w-window-wo-trim-closeup.jpg
Pat Harris
A HandyWOMAN Service, LLC
"Why call a handyman when you can call A HandyWOMAN?
pitterpat is offline
Old 10-27-2005, 10:16 PM   #2
pitterpat's Avatar
Trade: HandyWOMAN
Re: Window Leaks...Hmmm Wonder Why!
This is only a 6 yr old house. Under the window nailing flange there is some caulk and there is not some caulk. Up at the top of the window on the left side the caulk is kind of not there. I'm sure this is one of the places where the rain comes in and runs down the window to the window sill inside the house.
Any thoughts? I got some Protecto Wrap and will install that tomorrow. Then I'll put the new trim boards on, caulk, touch-up paint and be done.
This is an example of one of the problem builders in Indy.
Pat Harris
Old 10-27-2005, 10:35 PM   #3
TimNJ's Avatar
I ALWAYS flash where wood siding meets the top trim. Also, why is there no building wrap covering the OSB??
TimNJ is offline
Old 10-27-2005, 11:26 PM   #4
pitterpat's Avatar
Trade: HandyWOMAN
There is flashing...didn't you see that little piece that is part of the top flange. I got some flashing too to put up there too. Building wrap, you spect this builder to spend a little xtra on something like that? Seriously I was suprised too but I it was probably what I should have expected.
Get this, the opening to the screen door is 77 3/4" H normal 32" W. I had to get a $100 wood screen door and cut it down to fit. took like 3" off the bottom to make it fit.
This builder didn't do these folks any favors.
Pat Harris
Old 10-28-2005, 12:47 AM   #5
K2's Avatar
The flashing needs to go under the siding and over the window. Your probably getting a ton of water behind that head trim and it needs to find a way out or not get it in there to start with. I never cared for trimming lap siding the way your guys did it and that is one of the reasons. It would have been better if they dropped the siding on top of the head flange.
K2 is offline
Old 10-28-2005, 02:31 AM   #6
reveivl's Avatar
Trade: Renovations
Don't forget to do all the other windows in the house. Rich
reveivl is offline
Old 10-28-2005, 08:33 AM   #7
pitterpat's Avatar
Trade: HandyWOMAN
Well, that's something that me and the homeowner need to talk about. I'd like to but I don't know if it's in the budget.
Pat Harris
Old 10-28-2005, 08:46 AM   #8
K2's Avatar
I would think the windows under your flat soffits are pretty safe.
K2 is offline
Old 10-29-2005, 02:48 AM   #9
reveivl's Avatar
Trade: Renovations
"I would think the windows under your flat soffits are pretty safe."
The water was getting in behind the trim it looks like. Perhaps from the weep holes. If this is the case, if water can hit the window it's gonna be doing damage. Where that itty bitty head flashing is, although not properly done, doesn't seem to be causing the trouble here, so the presence of soffits might not be relevant.
Something to mention to your customer, Pitterpat, that way whenever they have any money you can fix a window and take it. Rich.
reveivl is offline
Old 10-29-2005, 05:27 AM   #10
pitterpat's Avatar
Trade: HandyWOMAN
There are only 2 more single windows that are not under the flat soffits. Takes about the same time to do single windows as this double window, most time is in getting the old trim off (pulling nails, cutting caulk).
Pat Harris
Replacement Window Question? Max10 Windows, Siding and Doors 34 02-27-2010 06:15 PM
Condensation Help Patrick Windows, Siding and Doors 10 03-16-2007 09:40 AM
Pre Cast Window Don H Drywall 7 09-20-2006 11:01 PM
Window Seat and Bookshelves in Fonr of Baseboard Heating Richie-C Finish Carpentry 10 04-04-2006 09:05 PM
Bay window Tonkadad Construction 11 12-13-2005 07:31 AM
