Window Bump Out Flashing?
Old 04-20-2009, 08:12 PM   #21
ebsworj's Avatar
Trade: Drywall
Re: Window Bump Out Flashing?
Originally Posted by genecarp View Post
I sure hope not
The granite will stop short 2" of the outside edge of the RO. So the window is at the height of the granite but not on top of it. Should I leave more? The counters are coming Saturday and I'm worried about this "box" i've made.
I do know I'll have to remove some of the siding to flash behind it but that's about all I know.
ebsworj is offline
Old 04-20-2009, 08:14 PM   #22
genecarp's Avatar
Unless you strip back the vinyle siding you will ba looking at caulking to be your primary water proofing, this is a NO---NO, if you strip it back you can wrap the whole system in tyvek window tape, start at the sill stick it to the sheathing, out along side your framing, and across the face, overlap all your seams from the bottom up. You can then break up aluminum, creating pans , again from the bottom up, then trim it out. in azek. G
genecarp is offline
Old 04-20-2009, 08:16 PM   #23
genecarp's Avatar
You will be ok, you have not f --ued up anything Yet, but you have to get the flashing correct. G
genecarp is offline
Old 04-20-2009, 08:20 PM   #24
genecarp's Avatar
It would have been nice to have the granite butt right against the new window, you would have had to have that dimension in order to have made that happen, now you will probably have some kind of trim between the granite and the window to complete the detail. G
genecarp is offline
Tags
bump out, bumpout, flashing, window
estimating guide for windows? Grumpy Windows, Siding and Doors 20 11-26-2010 08:18 PM
window flashing question--- davinci Windows, Siding and Doors 18 03-25-2009 04:26 PM
Reno Window Screw Up Bummie Windows, Siding and Doors 15 12-22-2008 10:33 PM
Window flashing advice colotimber General Discussion 10 03-04-2008 11:36 AM
Roof to wall flashing on a bay bump out??? wackman Roofing 18 02-26-2008 07:50 PM
