Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Specialty Trades > Windows, Siding and Doors
Old 04-28-2009, 09:02 PM   #1
Captainsls's Avatar
Trade: HARDSCAPE
Is this window broken?
I was wondering if I could get some help from this forum, as I belong over in the masonry forum and I'm terrible with carpentry.
I had a room plastered in my house, and the company opened a few of the windows. They are double hung Anderson windows. The top section of the window no longer is able to support itself... it just slides down if I unlatch the safety lock. None of the other windows operate like this, and they are only 5 years old. I dont see any way to "lock" the upper part so it stays up. Was some compression seal broken? Are they broken or am I missing something?
Thanks for any help
Captainsls is offline   Reply With Quote
Old 04-28-2009, 11:26 PM   #2
design build
javatom's Avatar
Trade: general
If it is a double hung window (both top and bottom are operational), you should see some type of release mechanism to lower the top sash. If you don't see anything, you have single hung and the top sash is not intended to move. It is possible but not likely that a single hung could come apart from the frame. If you have single hung and the top sash is still intact with the wood frame around the glass in good condition, you could re-attach it. Post a picture. It may help with suggestions you could get here.
javatom is offline   Reply With Quote
Old 04-29-2009, 06:02 AM   #3
Patrick's Avatar
Thanks for any help
The sash is not engaged in the balance. Tilt in the lower sash, and then tilt in the top sash to 90 degrees, lift it up and look into the tracks, and you will see where the sash needs to be locked into.
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline   Reply With Quote
Old 05-03-2009, 08:39 AM   #4
special ed
Trade: builder home improvements
are they tilt sash or none tilt if they don't tilt look to see if the sash cord has been cut they are in the vinyl jamb track. look at the top of the window jamb is there a metal clip there if that's the case you will have to remove the sash. to do this remove the screws on the left side of jamb and carefully remove vinyl jamb piece then pull the sash down and swing it out grip the metal clip with pliers and pull it down and put it back in the sash
if that's not the problem check the top of jamb to see if there is any nails in the trim that are new. the balances are in top of the framed if there is a nail in the balance they don't work ,pull the trim off and remove the nails
you said it was the upper sash if that's the case for the sash cord you will have to remove the lower sash first be careful to get a good hold on it with pliers they are under a lot tension
if none of this is the problem its the balance ,all the parts for this are available it can be fix no need to replace it. good luck let us know how you make out
EIDOL is offline   Reply With Quote
Old 05-03-2009, 02:27 PM   #5
Hammer and Nails
Hammer_Nail's Avatar
Trade: Kane County,Il Remodeling
Andersen
Can't you contact Andersen ? I used to do Service for our window dept, I would think they would help you.
Hammer_Nail is offline   Reply With Quote
Window insida Tile Shower orson Remodeling 13 12-24-2008 10:45 PM
Reno Window Screw Up Bummie Windows, Siding and Doors 15 12-22-2008 10:33 PM
Basement Window Leaking DanTheMan9727 Construction 3 10-24-2008 01:29 PM
estimating guide for windows? Grumpy Windows, Siding and Doors 9 09-10-2008 07:01 AM
Replacement Window Question? Max10 Windows, Siding and Doors 6 01-11-2007 11:49 PM
