Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Specialty Trades > Windows, Siding and Doors
Old 06-10-2008, 06:55 AM   #1
Trade: Woodworking
Post Window Boxes on Vinyl Siding
Can anyone tell me if there is a reason to not lag bolt window boxes onto vinyl siding? Seems like as long as you bolt through and hit some studs and then caulk the top and edges around the box to seal it in you'll be fine. I've had a dozen or so customers address concerns about drilling through their vinyl siding though, so I want to make sure I haven't overlooked something silly and obvious.
bookie203 is offline   Reply With Quote
Old 06-10-2008, 11:42 AM   #2
Trade: remod contractor
Vinyl has to be able to move for expansion and contraction
remod is offline   Reply With Quote
Old 06-10-2008, 10:57 PM   #3
Siding Windows Doors
easy sider's Avatar
Trade: Exteriors
You can install about any thing over the vinyl siding. When the object is removed the siding that was covered will be a different color after a few years. We drill holes into the shadow at the bottom of the lap of the siding to attach any thing.
easy sider is offline   Reply With Quote
Old 06-11-2008, 06:49 AM   #4
Trade: siding windows soffit fascia
Think about how many millions of shutters are mounted to siding in exactly the same way.
No problem.
Missouri Remodeling Company with services for Replacement Windows Vinyl Siding and Entry Doors
Home Serve is offline   Reply With Quote
Old 06-11-2008, 04:45 PM   #5
aren't the proper procedures for hanging (some) shutters to drill a 3/8" hole through the vinyl where the shutter screw penetrates? Some shutters have vinyl clips, which clip onto the vinyl siding versus screwing into the wall.
72chevy4x4 is offline   Reply With Quote
Old 06-13-2008, 11:34 AM   #6
brutis's Avatar
Trade: siding soffit hardie Tampa Fl
yep and then flash under the siding where the hole is down over the lock of next lower panel
there is a county here in fl. that will look for that , same with lower window corners , and flashing above windows of course ,
and they will fail inspection if not done the right way
brutis is offline   Reply With Quote
Siding: Aluminum vs. Vinyl Grumpy Windows, Siding and Doors 15 12-23-2008 11:46 PM
estimating guide for windows? Grumpy Windows, Siding and Doors 9 09-10-2008 07:01 AM
log cabin vinyl siding Home Serve Windows, Siding and Doors 6 04-28-2008 07:16 AM
Best method to replace a window with vinyl siding importer Carpentry 3 04-11-2008 08:10 PM
Fypon Window Crossheads and Vinyl Dentil Amar Windows, Siding and Doors 2 03-09-2008 08:30 PM
