Trade: brick layer
What Should A Low E Dual Pane Unit (28in X 76in) Cost Me
i broke one of my windows this weekend so I pulled out the stops and removed the glass, and was seeing if anyone knows how much just a Dual pane glass unit should cost me (28in x 76in). thanks
Trade: windows-siding
Re: What Should A Low E Dual Pane Unit (28in X 76in) Cost Me
depends on the window..a quality double pane vinyl could cost 600 bucks. high grade virgin vinyl with a composite spacer and high end soft coat lowE package.. or you could go to home depot and buy a silverline/american craftsman or a pella vinyl window and get seal failure in a few years...
some of the better windows are okna,gorrel.soft-lite. |
slave driver
Any local glass shop will be able to order you a replacement insulated unit,just remember to measure the width first,then height,and the overall thickness of the unit. also,it is important to give them the info about the unit make up,such as thickness of both lites of glass,spacer color and thickness,and if there are any interior muntins or grids inside the unit,industry standards are written as number of horizontal muntins or grid bars as verticles and horizontal ie, 4v and 2h,this tells then that there are 4 verticle and 2 horizontal muntins. but the most important thing is that glazing safety codes require that safety glass be used or installed where existing was,is required and NON safety glass can not be grandfathered in to replace where safety was/is. another thing to consider was the original unit made up with tinted glass,which is always the outboard lite,low-e glass which is always the inboard lite,and if there was any inert gass infill,such as argon gas.
your size of 28 by 76 sounds very close if not exact for a patio door glass size,usually 5/8 inch thickness,this can however vary up to 1 inch or more,past expierence places the cost around $200 for safety glass unit and $135 non safety,if you need any more info,just ask,hope this helps. |
Trade: Window Replacement and Window Repair
If you have only 1. We'll charge 375-400 depending on 1st or 2nd floor. Also location of your home. If you live in the metro expect to pay 375 including tax. Thats glass only. Now for a new vinyl window expect to pay 900-1000 installed for a rough opening window. These windows usually have to be tempered for code reasons. In KC we see these windows about 35-40% of the time. If you are going to live in your home longer than 10 years I would buy a replacement vinyl window. Better warranty.
Kyle Black Excellant Customer Service and Craftsmanship www.advantagewindowsolutions.com Last edited by kylecheezin; 05-01-2009 at 12:04 AM. |
| Practical GREEN ideas that don't cost much, part 1. | wackman | General Discussion | 24 | 03-15-2010 07:52 PM |
| Cost Based Bidding Vs Spreadsheet | sitegrader | Excavation & Site Work | 1 | 02-04-2009 10:44 PM |
| employee cost | Travis | Roofing | 10 | 12-30-2006 07:25 PM |
| New Central Air Unit for Ranch House | Robie | HVAC | 9 | 03-25-2006 10:01 PM |
