What Kind Of Truck Set-up Are People Using?
Old 03-01-2009, 02:05 PM   #21
EPD's Avatar
Trade: Carpentry/Contracting
Re: What Kind Of Truck Set-up Are People Using?
Id fire everyone near that trailer ... sure they probably make you money but thats straight up slob, imagine a customer peaking in there???
how can they be productive when they cant find half the tools and your tripping over ladders and vinyl scraps?!
i know ive been there
What kind of truck set-up are people using?-img00287.jpg   What kind of truck set-up are people using?-img00288.jpg   What kind of truck set-up are people using?-img00289.jpg
EPD is offline
Old 03-01-2009, 02:16 PM   #22
Patrick's Avatar
LOL a LOT of it had to do with me driving it around for 3 days in pot hole city
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline
Old 03-01-2009, 07:28 PM   #23
Gary H's Avatar
I took 16' flat bed trailer and welded racks 5' above the deck. Picks and pumpjacks go on top. Ladders and short picks go on the lower deck. 16' of tool boxes along the side to hold braces,guns,chaulk etc. A 10' brake hangs on the side that folds down. This is mounted with 2'' tubing. This took two years to figure out the correct angle and height. I added a bench to the top of the brake.
Gary H is offline
Old 03-02-2009, 05:36 AM   #24
WICKED WOODCHUCKER
mnjconstruction's Avatar
Trade: RESIDENTIAL CONTRUCTION, BUILDING & PROPERT MAINT.
I would love to see some pictures if you have any
mnjconstruction is offline
Old 03-02-2009, 10:35 AM   #25
Gary H's Avatar
I will post some on tuesday.
Gary H is offline
The Following User Says Thank You to Gary H For This Useful Post:
mnjconstruction (03-02-2009)
Old 03-02-2009, 10:56 AM   #26
Grand Rapids Remodeling
Paulie's Avatar
Those pics were funny as hell, made my Monday.
Paulie is offline
Old 03-02-2009, 02:41 PM   #27
rojigga's Avatar
Trade: Exterior Finishing
Originally Posted by grob62 View Post
sivlerado 1500 extended cab long bed with ladder rack, hauling 20' cargomate enclosed trailer with a table on one side for cutting metal, brake mounted on the other, shelves around. Going to upgrade to a 3/4 ton crew cab soon.
Originally Posted by paul100 View Post
We also use a 14' E350 with a pass through so we can slide a 32" ladder inside. One side of the truck is an empty wall where we can strap sheet goods or windows. We have some shelfs on the other side and toward the front. Our brake stays on the floor of the truck under the shelves. When we need it we just slide it out and set one end on the back of the truck and the other on a saw horse.
I use a 20' haulmark trailer which I really love (though sometimes it is a lil' big). Couldn't get everything I need at a jobsite without it! How does your 1/2 do pulling it loaded? I'd be a bit sketched with the transmission but if you have no troubles good on ya. I got a 1ton diesel for mine. I've posted pics before but I'll get one or two on this thread for y'all.
My business partner has been using his 14' cube van like the above post and he has his brake on the floor under shelving just like paul100 does. Doesn't take anytime to slide it out and support it with a sawhorse. Although I do like having my brake setup permanently in my trailer.
The pics make it look like I'm organized! It's pretty clean as there are a few tools already setup outside. Every few weeks I try and clean and maintain it as the longer you leave it the harder it is clean! Since I took these I got lights and power setup inside so I can keep it partially heated for my batteries and caulking.
What kind of truck set-up are people using?-1101081350a.jpg   What kind of truck set-up are people using?-1101081352.jpg   What kind of truck set-up are people using?-1101081350b.jpg
rojigga is offline
Old 03-02-2009, 04:00 PM   #28
user38755's Avatar
user38755 is offline
Old 03-02-2009, 04:07 PM   #29
user38755's Avatar
The Little Giants(3), set where the coil is setting, when all loaded up. The 24' plank holds them in place. Trailer is a '03 24' H&H, $5500 new.
Old 03-02-2009, 07:04 PM   #30
grob62's Avatar
Trade: Windows and Doors
Milkcrates as shelves! That's hillbillified. I had one like that myself until somebody put something too heavy in it and down it came.
grob62 is offline
Old 03-02-2009, 07:12 PM   #31
grob62's Avatar
Originally Posted by rojigga View Post
(How does your 1/2 do pulling it loaded? I'd be a bit sketched with the transmission but if you have no troubles good on ya.
180,000 miles and going strong, It squats a bit when loaded with a bunch of windows. I bought the truck new in Feb 2001, then later bought the trailer in September, but it has worked out. I am planning the upgrade to 3/4 ton crew cab, with probably a short bed within the next 6 months.
grob62 is offline
Old 03-02-2009, 08:08 PM   #32
rojigga's Avatar
Is it legal to pull your trailer with that truck? I thought they'd have to be bulked up to haul a load like that around. I think that's how it is here in BC. I guess if it's empty you'd be alright.
rojigga is offline
Old 03-03-2009, 04:20 PM   #33
TRC
TRC's Avatar
So, so far trailers seem to be the favorite choice? I'm on the fence about new enclosed trailer or box truck. 20' seems too long to easily get in and out of driveways. Do you guys ever have that problem?
TRC is offline
Old 03-03-2009, 04:56 PM   #34
Gary H's Avatar
Gary H is offline
Old 03-03-2009, 05:08 PM   #35
Gary H's Avatar
Here you go. The brake swing s down, and the chains hold it level. We tried it without chains and it hung low. As you lift it up the tubing that holds the brake slides into a reciver. Two hitch pins slide behind the tubing. Chains are also welded to these to prevent losing them. If I did it again I would build a 100% alum. trailer. No painting or rust. The work bench is made up of alum. angle and bolted to the brake. 3/4'' painted plywood sit on top. A good place to put cutter,formers, and scrap. The coil holder is welded to alum. pipe and slides in the alum. tubing at the end of the brake. Working on a place to hang the slitter. Mentalbender has a good set up too. Everything out of the weather.
Gary H is offline
Old 03-03-2009, 06:42 PM   #36
WICKED WOODCHUCKER
very nice setup!!!
Old 03-03-2009, 06:59 PM   #37
Gary H's Avatar
Thanks.
Gary H is offline
Old 03-03-2009, 09:49 PM   #38
Patrick's Avatar
The only thing that sucks about having the brake in an enclosed trailer is its a PIA to bend facia and rake. But if your just making windows its ok.
Patrick is offline
Old 03-03-2009, 10:59 PM   #39
grob62's Avatar
Never got a ticket for improperly vehicle. Been warned for speeding. I'm curious why would it make a difference? I've seen guys hauling trailers with minivans. Granted not a 20' trailer but still.
More curious, why three mitre saws? Interior Trim, Exterior Trim, and aluminum? Just a guess.
Your setup looks really good. Where do your ladders go?
grob62 is offline
Old 03-03-2009, 11:30 PM   #40
user38755's Avatar
Right on. I open the side door, stick it out and rotate it. Had a brake on either side at one time. Faster, but took up to much space. And to answer another ? , yes steep drives are a problem. We work mostly new construction, and rural areas. Cities are a problem with a 24' trailer for sure.
Call The Brinks Truck The Hurricane Is Here! Carport King General Discussion 4 08-19-2008 10:29 AM
R.O. / Stinger Truck Wanted Praire Coast Welding & Steel Trades 0 08-16-2008 07:57 PM
T-bone a Mail Truck - what to do magnets Off Topic (Non Trade) 8 10-15-2007 12:12 AM
Painted My Truck With a Roller ModernStyle Painting & Finish Work 44 07-21-2007 10:11 PM
