What Causes This To Happen ?
Old 03-02-2009, 10:30 AM   #21
Siding Windows Doors
easy sider's Avatar
Trade: Exteriors
Re: What Causes This To Happen ?
If this is thermal bridging, why is it only happening to the end walls ? Maybe I should go back to the building and unlock a pannel off the front or back to see if the wall is constructed differently than the ends.
easy sider is offline
Old 03-02-2009, 10:37 AM   #22
Grand Rapids Remodeling
Paulie's Avatar
Yeah why not? Look behind the panel. I putting my bet on thermal bridging because it follows the studs. How else can you explain it?
By the way are there bathrooms against the end walls? I see what looks like fart fan exhausts in the one picture.
Paulie is offline
Old 03-02-2009, 10:46 AM   #23
KemoSabe
loneframer's Avatar
If they aren't fire rated, they probably are done differently. I've done alot of this type of construction, fire rated sides, conventional plywood construction front and rear. Just a thought, are the walls stained within 4' of the corner? There could be a fire rated plywood shear panel on the corners, but not necessarily.
loneframer is offline
Old 03-02-2009, 12:16 PM   #24
easy sider's Avatar
Trade: Exteriors
We feel that this is thermal bridging. What can be done to eliminate this problem. Would 1/4 fan fold underlayment be enough to keep this area warm enough ? Is there a product that is thin enough to slip under the outside corners that would stop the thermal bridging ?
Thanks
Bill
Old 03-02-2009, 12:24 PM   #25
KemoSabe
loneframer's Avatar
Thanks
Bill
I think the culprit is the siding being stud nailed because of the fire rock. the stud is the path of least resistance, even with fanfold the nail continues to be the conductor. It may be worth a shot but I wouldn't wager on it. Most siders don't bother stud nailing with traditional sheathing, although I do because of the coastal storms in this area.
Old 03-02-2009, 12:47 PM   #26
Paulie's Avatar
I had a job somewhat similar. No firerock, standard residential construction but had pipes freezing on outside wall and didn't want to tear off corners. I used 3/8's fan fold with mylar. I didn't think it would help just being 3/8's. I just checked on it this last november and they said they never had a problem since.
I understand what loneframer is saying about the nailing (and I agree) but what else can you do?
Paulie is offline
Old 03-02-2009, 01:57 PM   #27
Sophisticated Siding Guy.
thesidingpro's Avatar
Trade: Siding and Trim Specialist
You have to stud nail no matter what type of sheathing. Plain and simple.
thesidingpro is offline
Old 03-02-2009, 02:17 PM   #28
KemoSabe
loneframer's Avatar
I agree, I'm just saying many "pros" don't, and many builders don't know any better. I see it over and over again. As well as poor flashing and papering details. Water management should be job one for a siding co. and rarely is, or in my experience, never is.
Old 03-02-2009, 02:21 PM   #29
pro's don't hacks do. Huge difference.
And I agree. I see it blowing off all the time and most cases a catching the studs was all would have been needed.
There was a crew around here that stapled everything without worrying about studs at all. It's flying off everywhere.
I know because I lost a bunch of work to this outfit several years ago based on price.
Old 03-02-2009, 02:28 PM   #30
KemoSabe
loneframer's Avatar
It jerks my gherkin that these guys are making money hand over fist while producing sub-standard product. No pride and no passion, just a paycheck.
Old 03-02-2009, 02:49 PM   #31
rojigga's Avatar
Trade: Exterior Finishing
Not only that who likes to nail into sheathing without a stud behind it? Way harder when theres no support behind it. Damn sheathing's to bouncy in between studs!
rojigga is offline
Old 03-02-2009, 03:34 PM   #32
KemoSabe
loneframer's Avatar
Yes, but for many, close to stud will suffice.
Old 03-02-2009, 08:13 PM   #33
rojigga's Avatar
True enough loneframer, true enough.
rojigga is offline
Old 03-02-2009, 08:25 PM   #34
easy sider's Avatar
Trade: Exteriors
Ok. I looked under the front and back wall and it is sheeted with plywood. No problem on these walls. I sent pictures to Alan Hoying, R&D at Ply Gem, formerly Alcoa, and am waiting for his departments collective thoughts.
Thanks for all the educated guesses.
Bill
Old 03-02-2009, 08:30 PM   #35
Bill Z's Avatar
Trade: sun rooms and room additions
The back side of the siding looks fine. The nails are 2 " eg roof with no discoloration. The siding is nailed to studs under sheetrock. This is only happening on walls where the electric meters and utilites are located.
Thaks
Bill
Just curious about roofing nails with aluminum siding. When I started in the siding business, everything was aluminum siding and we ALWAYS used aluminum nails because of the reaction between galvanized products and aluminum. It wasn't until vinyl became popular that we used roofing nails for siding.
Any possibility of a reaction between the aluminum and the galvanized?
Bill Z is offline
Old 03-02-2009, 08:37 PM   #36
KemoSabe
loneframer's Avatar
I think you may have something there. I missed the fact that it was Aluminum siding, electrolosis could very well be the culprit, only thing that baffles me now is why end walls don't have the same problem. Hmmmmmm, why then would it not only show at the nailing hem coarse. Hmmmmmm
Old 03-02-2009, 08:42 PM   #37
Bill Z's Avatar
Maybe the heat and/or moisture from the dryer vents, assuming there's a slight breeze from the right of the picture, speeds the process? Or perhaps the proximity to the electric meter does it?
Bill Z is offline
Old 03-02-2009, 10:00 PM   #38
easy sider's Avatar
Trade: Exteriors
This is ALCOA SUPER V D-4. The v stands for vinyl. This was the early generation of Alcoa vinyl siding before Alcoa aquired Mastic. Alcoa stoped production of Super V around 1990-91.
VSI states e.g. roofing nails are a suitable fastener for vinyl siding.
Thanks siders
Bill
Old 03-02-2009, 10:15 PM   #39
Bill Z's Avatar
Thanks siders
Bill
Aah, shows how long ago I messed with siding. Just automatically matched Alcoa to aluminum. My bad, blows my theory,,,,, since it's vinyl, I go with the static electricity theory. Many years ago, when selling aluminum, we rubbed the vinyl and created static to show how vinyl would attract dirt. Maybe that's actually happening now....
Bill Z is offline
Old 03-02-2009, 10:19 PM   #40
KemoSabe
loneframer's Avatar
Shnap man, I go and jump on the electrolosis wagon and the damn wheels fall off. Back to the thermal bridge theory for me.
New gas tax that isn't going to happen Leo G General Discussion 31 02-27-2009 12:05 AM
I've been RIPPED OFF Don't let it happen to you! arnldmtman General Discussion 2 03-12-2008 02:09 PM
Anyone ever have this happen??? J F General Discussion 47 02-15-2008 10:51 PM
It could only happen to me lxdollarsxl General Discussion 54 09-30-2006 04:10 PM
what happen to my computer? izote61 Technology 13 10-19-2005 12:54 AM
