Wavy Siding
Old 12-13-2008, 10:35 PM   #1
forsmant's Avatar
Trade: General Contracting, Remodeling
Wavy Siding
What is the best way to stop lap siding of any kind from waving from stud to stud? Is plywood or osb the preferred sheathing when using lap siding?
forsmant is offline
Old 12-14-2008, 08:53 AM   #2
Bah Humbug!
Grumpy's Avatar
Re: Wavy Siding
1/2" insulation should do the trick. Of coarse the siding should be loosely nailed. The nailes should penetrate through the insulation, sheating and into the studs. The siding should basically just hang on the nail.
Grumpy is offline
Old 12-20-2008, 12:19 PM   #3
Tom Struble's Avatar
Trade: siding
Re: Wavy Siding
if your looking at it from dead on corner to corner you always see some waves hardie is even worse in that way also because your nailing hard
Tom Struble is online now
Old 12-20-2008, 05:45 PM   #4
CharlesD's Avatar
Trade: Remodeling/building
Re: Wavy Siding
Eyeball down each course of siding then use scrap strips of foam or even strips of cardboard cut from your siding boxes to fur out uneven studs. If the wall is really bad you can use lathes
It takes time but shows quality in your siding jobs.
CharlesD is offline
Old 12-20-2008, 05:56 PM   #5
Trade: siding
Re: Wavy Siding
my exierience has been you can only shim so much before you start getting problems with corners and window and soffit its easy to say foam and cardboard shims but ive had wall change course to courseits not so much the studs sometimes but the sheathing between them
Siding & Windows Sales needed - Chicago area - NO SALES EXPERIENCE Grumpy Help Wanted or Looking For Work 4 05-26-2009 03:51 PM
siding an old house gtmstang Windows, Siding and Doors 14 12-20-2008 06:21 PM
Nailing cedar bevel siding Chris B Carpentry 2 08-25-2008 03:33 PM
log cabin vinyl siding Home Serve Windows, Siding and Doors 6 04-28-2008 08:16 AM
Watertight integrity of viynl siding? mci2980 Windows, Siding and Doors 71 11-24-2007 04:15 PM
